Idiot's guide to bridge mode
FIXED- Subscribe to RSS Feed
- Re: Idiot's guide to bridge mode
4 weeks ago
I'm back in but it's being a pain. When I sort those boxes there is then another Next button and when I clicked this I got an error message but it saved the connection and now gives me an error message when I try to remove it and start again.
Thank you so much for your patience with this.....
4 weeks ago
Not sure how changing the WAN connection information should cause that.
or via the Hub 2.
You willnot be able to connect to the billion gui from a device connected directly to the Hub 2.
So from a device connected via ethernet you can't access the billion gui using its 192.168.168.x address ?
Have you tried a reset ( not a factory reset ) ?
4 weeks ago - last edited 4 weeks ago
@MisterW I had to delete the Wan service ethernet setting and start again and found that the Hub 2 had allocated a different IP address to the Billion.
I now have the Hub 2 connected to the internet, an ethernet cable from LAN 3 on the Hub 2 to the WAN port on the Billion and an ethernet cable from a LAN port on the Billion to my laptop.
AND MY LAPTOP IS CONNECTED TO THE INTERNET via that connection 😁
But I can't seem to get to the Billion gui anymore - it I enter the LAN IP address that the Hub 2 has given it, I don't get anything? It asks for the username and password but then nothing just returns to that screen
4 weeks ago
Now got to this - does it look right? But no options in the left column so I can't get through to the Billion stats pages. Reloaded a few times stays like that.
4 weeks ago
From a device connected to the billion, you use the LAN IP that's set in the Billion, 192.168.168.x IIRC from earlier posts. Just like you did before the Hub 2 came into the picture.
The Hub 2 assigns an IP address to the WAN port of the billion, you will not be able to access the billion gui using that.
If think about it like this , the WAN port of the Billion represents the outside world ( the internet in normal circumstances ) and you would not normally allow acces to its gui from the internet. The fact that the WAN port is now connected to the internet via a Hub 2 makes no difference, the Hub 2 is still the outside world and so no access to the billion gui is possible from anything connected directly to the Hub 2
@Junkman Now got to this - does it look right?
That looks absolutely right and what I was expecting.
If you mean DSL stats like line speeds , then there arent any on the Billion, its not making the DSL connection now, the Hub 2 is. So to look at the DSL stats, you use the Hub 2 gui. Use the address 192.168.1.254 to get to the Hub 2 gui. That should work from either a device connected to the Billion or the Hub 2.
ISTR the line stats on the Hub 2 are shown in the Advanced settings, Technical log , maybe @Dan_the_Van can confirm
4 weeks ago
Advanced settings >Broadband gives you the public IP Address
4 weeks ago
@MisterW @Dan_the_Van I can't thank you enough for sticking with me through this as I would never have got there on my own. I've now reconnected my mesh system and all my devices seem to be connected and working OK. I'm synced at 30.7 which is slightly lower than I was before I made all the connection breaks today. Will see where the Hub 2 takes that (if anywhere). Plusnet are scheduled to call me back next Monday so there's a bit of time for DLM to adjust back to where it was (for 2 years+ prior to April 13th) if it's going to. And if having the Hub 2 connected doesn't facilitate them sorting the line issue for me then I can just go back to where I was before.
Just need to tidy up all the connections now but will leave that until tomorrow as it's gonna mean another disconnect.
Thanks again gents - and I hope this thread is useful for anyone else who might have a similar problem.
4 weeks ago
@Junkman happy to help. I'm not sure we've completely finished yet until you've tested access to your virtual servers etc
but maybe that can wait a day or so...
4 weeks ago
Also pleased to help, let me know if you get stuck with setting up port forward rules as I have a few on mine or any further Hub Two related questions.
First problem gents. How do I get this back? I have a Fixed IP with Plusnet and it's linked to that, but these changes have stopped it working. Most useful tool to monitor latency, packet drop and drop-outs. Looks like it was working when I first set up the new arrangement successfully but has lost it since? Just checked and I'm still on that same fixed IP.....
Ah - might have sorted it. Hub 2 default is not to allow incoming pings
yes, the IP is associated with the account,so won't change with a router change
yep, that'll do it...
4 weeks ago
4 weeks ago
Let me have a think, I assume it will keep till tomorrow
For BMQ to work you need to enable Incoming Pings found in Home >Advanced Settings >Firewall >Configuration look for
Edit: did you save the change ?
