drive capacity
- Re: drive capacity
- « Previous
- 1
- 2
- Next »
Re: drive capacity
10-12-2008 5:30 PM
I didn't go into details because it is not solved as many would like it to be on their own machines. I still don't have recognition of the drives full capacity but looking in disk management on my XP it shows 297.96 GB out of a drive capacity of 320GB. It is solved in so far as will settle for that . Thank you for your help - and to Samuria for the links..
Re: drive capacity
10-12-2008 5:59 PM
That's probably 100% correct.
Drive manufacturers have a habit of using K=1000, M=million, G=Billion whereas Windows is probably using 1024, 1,048,576 and 1,073,741,824. It makes the drives look bigger - marketing eh!
320 Billion bytes is actually about 298GB.
Re: drive capacity
10-12-2008 6:06 PM
Aha, that's actually fairly easily explainable.
File sizes are recorded in Kilobytes and Megabytes. One Kilobyte is 1024 bytes, and one Megabyte is 1024 Kilobytes and so on.
Hard drive manufacturers use a completely decimal representation, where one Kilobyte is referred to as 1000 bytes, and one Megabyte is referred to as 1000 Kilobytes and so on.
So, a hard drive manufacturer will quote their sizes as being 320Megabytes: 320*1000*1000*1000 = 320000000000 bytes
When the drive is formatted, it shows the representation as: 320000000000 / (1024*1024*1024) = 298.02 Gigabytes
Re: drive capacity
10-12-2008 6:22 PM
Snap (pay attention Barry!)
Re: drive capacity
10-12-2008 7:02 PM
Oh ! unlike the portly Belgian detective, it seems my little gray cells are not all they should be. I should have remembered the difference that you point out. So, It's good to know that I'm getting the full use of my drive.
- « Previous
- 1
- 2
- Next »
