USB to Parallel 36 Pin Centronics Printer Cable
journeys
Anyone have any experience with these, there are dozens on ebay
OS win 7 (64 bit), most specify win 7 (32 bit)
Printer HP LJ 5
4 REPLIES 4
TORPC
Re: USB to Parallel 36 Pin Centronics Printer Cable
According to this listing
Specification:
    USB - IEEE 1284
    USB 1.1 compliant, compatible with USB 2.0
    1 mtr in length
    Compatible with Windows XP, Vista & Windows 7(32 & 64bit)
Did phone another supplier and was told it wont fit the 64bit
HairyMcbiker
All Star
Fixes: 21
I have one, only ever used it in Linux though (32 & 64bit) no drivers needed there. If you need a driver then you may have issues but I don't remember the one I have coming with a disk  Huh
shutter
Fixes: 65
MauriceC
Resting Legend
Fixes: 17
I never had much success using a USB to Centronics adapter - albeit I was using an old LaserJet3.  The bi-directional component never worked.properly.
If you do need to keep the LaserJet5 operational, you could try using a HP JetDirect box to convert the printer to a Networked printer?  I've successfully got a jetdirect500 to drive a much loved LaserJet3 working on Windows7.  Another option is to add a Jetdirect card into the Laserjet5....    Both items currently available on Ebay  between £2 and £20
Maurice
