USB to Parallel 36 Pin Centronics Printer Cable
- Re: USB to Parallel 36 Pin Centronics Printer Cabl...
28-02-2014 7:33 AM
Anyone have any experience with these, there are dozens on ebay
OS win 7 (64 bit), most specify win 7 (32 bit)
Printer HP LJ 5
Printer HP LJ 5
4 REPLIES 4
Re: USB to Parallel 36 Pin Centronics Printer Cable
28-02-2014 8:26 AM
According to this listing
Did phone another supplier and was told it wont fit the 64bit
Quote Specification:
USB - IEEE 1284
USB 1.1 compliant, compatible with USB 2.0
1 mtr in length
Compatible with Windows XP, Vista & Windows 7(32 & 64bit)
28-02-2014 9:36 AM
I have one, only ever used it in Linux though (32 & 64bit) no drivers needed there. If you need a driver then you may have issues but I don't remember the one I have coming with a disk
![Huh Huh](/html/@E2297E1574AC8AB2FE5882A8865382BF/images/emoticons/huh.gif)
28-02-2014 9:53 AM
Would any of these be of use ? ?
http://www.cablesnmor.com/db25-female-36-pin-male-adapter.aspx
28-02-2014 6:51 PM
I never had much success using a USB to Centronics adapter - albeit I was using an old LaserJet3. The bi-directional component never worked.properly.
If you do need to keep the LaserJet5 operational, you could try using a HP JetDirect box to convert the printer to a Networked printer? I've successfully got a jetdirect500 to drive a much loved LaserJet3 working on Windows7. Another option is to add a Jetdirect card into the Laserjet5.... Both items currently available on Ebay between £2 and £20
Maurice
Maurice
