Reversible USB cable / connectors
It is annoying to have to get the polarity / alignment of many cables correct to insert the connector into the appropriate socket.
Especially USB connectors which may be plugged frequently
Now a reversible USB connector / socket is on the way.
Personally, I just stick a small blob of Blu-Tak onto the upwards facing side of the connectors, for USB, HDMI etc
For myself, mainly for mobile phone charge cables, daily !!
With mini and micro connectors.
Tipp-ex would be a good alternative. (other makes available)
http://www.redmondpie.com/heres-what-the-reversible-usb-3.1-typec-cable-looks-like-images/?utm_sourc...
19 REPLIES 19
picbits
Re: Reversible USB cable / connectors
USB cables have a symbol on one side to show you which way up it should go.
Understood, but difficult to see, especially in low light, or shaded, or round the back of an item, or inserting by touch ....
Or Vertical.
USB sticks with no indication of polarity benefit too.
And phone connectors, the bit that plugs into the phone, are just plain minuscule
gleneagles
Aspiring Legend
Fixes: 17
Perhaps a small pot of luminous finger nail paint might do the trick if you have no tippex
We are born into history and history is born into us.
TORPC
Can you see any of the guys on here going to the make up shop(s) to purchase "luminous finger nail paint"
I can just imagine the funny looks from the staff & customer(s) of the shop(s) in question
Grin  Grin Grin
rongtw
Fixes: 12
here you go  Wink  easy new USB
http://www.bbc.co.uk/news/technology-26868531
NedLudd
I have a USB drive caddy that needs two USB leads (power & data). One of my cables (data) has the logo on the top and the other (power) has it on the underside!  Undecided
Go figure.  Roll_eyes
Geoff,
York.
billnotben
I always go by the join in the metal as this always seems to be the underside.
TORPC
It would help if manufacturers would keep them all the right way up, (as an industry standard) instead of swapping them around on different models et al
"seems to be the underside."
That is ok on on the plug itself
What happens when you got to be a contortionist in a clients Business / Home when they have their devices hidden in cupboards et all that have been D.I.Y Built custom made that one would spend more time un-nailing / un-screwing etc than the it would take to fix the device in question, & they have not thought of installing a USB Hub etc ?? ?? ?Huh
HairyMcbiker
All Star
Fixes: 21
I usually find the correct way by :-
Trying to insert
reverse
try to insert
reverse
it fits.
Now I have NEVER found out why it will not fit the first time, but it usually takes those 3 tries.
TORPC
Snap
I think it's a curse of the USB Gremlins  Grin Grin Wink
VileReynard
Fixes: 20
Why are mini/micro USB connectors the traditional D-connector shape?
TORPC
Good question that only the designer(s) / manufacturers may only have the answer
NedLudd
Quote from: billnotben
Both have the join on the top!!!
But, my expansion card is the other way up - the join is underneath!
Roll on Dual Fuel USB!  Wink
Geoff,
York.
Alex
Fixes: 13
Quote from: Hairy
Trying to insert
reverse
try to insert
reverse
it fits.
That's my usual system too, trouble is the insert part the other week fitted, but it didn't work. I spent a couple of minutes wondering why. (can hardly reach the back of my PC).
Learnt that USB devices work better when plugged into a USB port, rather than the Ethernet one next to them. Roll_eyes
