Reversible USB cable / connectors
- Re: Reversible USB cable / connectors
03-04-2014 12:46 AM
Especially USB connectors which may be plugged frequently
Now a reversible USB connector / socket is on the way.
Personally, I just stick a small blob of Blu-Tak onto the upwards facing side of the connectors, for USB, HDMI etc
For myself, mainly for mobile phone charge cables, daily !!
With mini and micro connectors.
Tipp-ex would be a good alternative. (other makes available)
http://www.redmondpie.com/heres-what-the-reversible-usb-3.1-typec-cable-looks-like-images/?utm_sourc...
03-04-2014 7:47 AM
03-04-2014 7:55 AM
Or Vertical.
USB sticks with no indication of polarity benefit too.
And phone connectors, the bit that plugs into the phone, are just plain minuscule
03-04-2014 3:44 PM
03-04-2014 3:48 PM
Can you see any of the guys on here going to the make up shop(s) to purchase "luminous finger nail paint"
I can just imagine the funny looks from the staff & customer(s) of the shop(s) in question
03-04-2014 4:06 PM
http://www.bbc.co.uk/news/technology-26868531
03-04-2014 5:04 PM
Go figure.
York.
03-04-2014 5:34 PM
03-04-2014 6:03 PM
"seems to be the underside."
That is ok on on the plug itself
What happens when you got to be a contortionist in a clients Business / Home when they have their devices hidden in cupboards et all that have been
03-04-2014 6:08 PM
Trying to insert
reverse
try to insert
reverse
it fits.
Now I have NEVER found out why it will not fit the first time, but it usually takes those 3 tries.
03-04-2014 6:23 PM
I think it's a curse of the USB Gremlins
03-04-2014 6:50 PM
03-04-2014 6:52 PM
03-04-2014 7:06 PM
Quote from: billnotben I always go by the join in the metal as this always seems to be the underside.
Both have the join on the top!!!
But, my expansion card is the other way up - the join is underneath!
Roll on Dual Fuel USB!
York.
03-04-2014 9:55 PM
Quote from: Hairy I usually find the correct way by :-
Trying to insert
reverse
try to insert
reverse
it fits.
That's my usual system too, trouble is the insert part the other week fitted, but it didn't work. I spent a couple of minutes wondering why. (can hardly reach the back of my PC).
Learnt that USB devices work better when plugged into a USB port, rather than the Ethernet one next to them.
