Really in the dark about this.
ForeverArsenal
Hi.
With plusnet for years connected via netgear dg834 and ethernet cable.
to desktop computer upstairs.
This above computer is wireless capable but never looked into it.
Is 3 years old.
Wife now getting idea about wanting laptop to research family tree downstairs Cry
Would be hard to run long ethernet cable downstairs.
Don't know anything about going wireless so may be back here for loads of help Grin
So first things first,as far as I know wireless works @  2.4 GHz  Huh
I have cctv camera's x2  that work on  2.4 GHz.So before going any further with
questions would this be a problem please re interference.
Thanks.
Baz.
5 REPLIES 5
ForeverArsenal
Re: Really in the dark about this.
I can now tell you tell you they do. Sad
Fixes: 1,484
You could try A or N which work on 5Ghz for your wireless..
jelv
Fixes: 10
An alternative to wireless would be homeplug which works over the electricity ring main. You plug one in upstairs and connect it to the router. You plug a second unit in anywhere else in the house and connect the laptop to it using an ethernet cable.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Denzil
Before you go and buy any other kit, just try changing the wireless channels on the router. Shifting to a channel with a slightly different frequency may avoid the interference.
jelv
Fixes: 10
Quote from: ForeverArsenal
A bit difficult to try to change the wireless channel on that router. Wink
The point is he doesn't want to splash out before he knows if it will work!
