Really in the dark about this.
- Re: Really in the dark about this.
31-12-2009 5:07 PM
Hi.
With plusnet for years connected via netgear dg834 and ethernet cable.
to desktop computer upstairs.
This above computer is wireless capable but never looked into it.
Is 3 years old.
Wife now getting idea about wanting laptop to research family tree downstairs![Cry Cry](/html/@6B4B63041062049E874E6843927E9ADE/images/emoticons/cry.gif)
Would be hard to run long ethernet cable downstairs.
Don't know anything about going wireless so may be back here for loads of help![Grin Grin](/html/@D40767E4EBB99989487344F3E42E44B1/images/emoticons/grin.gif)
So first things first,as far as I know wireless works @ 2.4 GHz![Huh Huh](/html/@E2297E1574AC8AB2FE5882A8865382BF/images/emoticons/huh.gif)
I have cctv camera's x2 that work on 2.4 GHz.So before going any further with
questions would this be a problem please re interference.
Thanks.
Baz.
Is 3 years old.
Thanks.
Baz.
5 REPLIES 5
09-01-2010 11:56 PM
I can now tell you tell you they do.
![Sad Sad](/html/@5863905B9AC6EE4F2B28C1A2965ABC0C/images/emoticons/sad.gif)
10-01-2010 12:08 AM
You could try A or N which work on 5Ghz for your wireless..
10-01-2010 9:56 AM
An alternative to wireless would be homeplug which works over the electricity ring main. You plug one in upstairs and connect it to the router. You plug a second unit in anywhere else in the house and connect the laptop to it using an ethernet cable.
10-01-2010 12:20 PM
Before you go and buy any other kit, just try changing the wireless channels on the router. Shifting to a channel with a slightly different frequency may avoid the interference.
10-01-2010 12:58 PM
Quote from: ForeverArsenal connected via netgear dg834
A bit difficult to try to change the wireless channel on that router.
![Wink Wink](/html/@ED8EAB3707DE077FFF94EEBAB958E3C6/images/emoticons/wink.gif)
The point is he doesn't want to splash out before he knows if it will work!
