Hub2 blue light.
Fedupdaz
Hub2 blue light.
New Hub 2 setup and connected ok to wifi. However the blue light is not a complete circle, just lit at top and bottom?
5 REPLIES 5
Fixes: 420
Re: Hub2 blue light.
@Fedupdaz  Welcome to the forum.
That’s how it’s designed to look.
Fedupdaz
Ok thanks very much.
robsie
Thanks for the info, is there away to set the blue light to a full circle.
regards
robsie
Fixes: 420
@robsie
In a word, no. You can dim it or switch it off in the settings.
robsie
That's a shame would look better in a full circle rather than two arcs.
Regards
robsie
