HDMI cable advice, Please
- Re: HDMI cable advice, Please
25-09-2013 2:37 PM
Currently, in the box is a lead with RED, YELLOW, and WHITE (audio) plugs on one end and a 4 section jack plug on the other.... which goes into the phones socket. for TV OUT...
This is a short lead, and from previous experience, has not worked well,.... a friend suggested I get a HDMI cable,... as this gives better signal transfer or something...
There is a mini USB socket for charging and connecting to USB2 on the laptop to transfer files... and I am thinking this might be the answer... There seems to be several different things on Ebay ( with varying prices)... and I would like some advice on which one to get...
Over to you.... my expert friends......
http://www.ebay.co.uk/sch/i.html?_trksid=p2050601.m570.l1311.R2.TR5.TRC0.A0.Xusb+to+hdmi+&_nkw=usb+t...
25-09-2013 2:43 PM
If Yes just buy a £1.00 HDMI cable
[Edit]
You can get them from Poundland, if you have one!
Out of curiosity what is the MP4 player?
25-09-2013 3:19 PM
This is the item .....
http://www.ebay.co.uk/itm/UK-STOCK-White-HD-1080P-Touch-Screen-16GB-4-3-MP3-MP4-MP5-TV-Out-Video-Pla...
I bought it cos it was "uk stock".... however, checking the feedback gave me some concerns and was worried about what was coming.... only just received it about 2 hours ago,... seems to be "what it says on the box"... it does play, and the other functions seem to be working... ( just a quick check,... cos I`m only interested in the MP4 player... ) It has 14.3Gb spare.. ( plus the OS ) making 16Gb total...
25-09-2013 3:22 PM
Quote from: shutter a lead with RED, YELLOW, and WHITE (audio) plugs on one end
Standard leads, your TV should have a corresponding set of 3 input sockets. It's for video and stereo (L/R).
If there's no HDMI connector on the device just forget about it.
Edit. Just read the device spec. Definitely no HDMI, just TV out using those leads. You can probably buy extensions to them.
25-09-2013 3:30 PM
Will look to see if there is some extension leads... If not.. I am capable of making some up....
25-09-2013 3:34 PM
25-09-2013 6:11 PM
25-09-2013 6:19 PM
I`d just like to see my vids on the BIG screen !
25-09-2013 6:34 PM
Quote from: shutter I`d just like to see my vids on the BIG screen !
They'll probably be fine as long as you don't sit too close.
25-09-2013 6:48 PM
25-09-2013 8:04 PM
25-09-2013 9:07 PM
Quote from: shutter Have bookmarked that rca scart adapter....
It is literally that, an adapter. No change in signal quality.
You only need one if your TV has a spare SCART connector but NOT the 3*RCA connector group. Unlikely TBH.
25-09-2013 9:21 PM
25-09-2013 9:24 PM
P.S....... Thanks for that Strat.... have bookmarked that also for further investigation !... ( ain`t this fun ! ! ! )....
26-09-2013 8:16 AM
http://www.ebay.co.uk/itm/3-Phono-Male-to-Female-RCA-5M-A-V-Extension-Lead-Triple-Audio-Video-Cable-...
Phono plugs on one end, phono sockets on the other...
