CASH REWARD - CCTV - RTP/RTSP and other issues
- CASH REWARD - CCTV - RTP/RTSP and other issues
14-02-2012 11:33 AM
I currently have a Y-CAM bullet camera set up at home and can view it perfectly from anywhere, including work. I have also recently got a Swann system and can view that from anywhere except work.
Now the thing I am struggling with is how to tie up the ports that I have on the Y-cam to those of the Swann.
Below are the 2 network setting pages from the Y-cam
![](http://i1090.photobucket.com/albums/i365/SMARTCROSSBLADE/CCTV/Y-CAMUPNPSettings-1.jpg)
![](http://i1090.photobucket.com/albums/i365/SMARTCROSSBLADE/CCTV/Y-CAMTCPIPSettings-1.jpg)
These 2 links are larger versions of the 2 above.
http://i1090.photobucket.com/albums/i365/SMARTCROSSBLADE/CCTV/Y-CAMUPNPSettings.jpg
http://i1090.photobucket.com/albums/i365/SMARTCROSSBLADE/CCTV/Y-CAMTCPIPSettings.jpg
Now on the Swann system they use a media port and a web port. The best I can show you is page 23 of the manual here. They are set as Media = 9000 and Web = 3100
http://www.swann.com/webfiles/download/1540DVR4-1200_M41200H200111E_web.pdf
How do I get the equivalent Y-CAM ports into the Swann system so that i can use that instead. All this RTP and RTSP ports on the Y-CAM has got me lost.
To access the cameras via my browser I type (where MYIP would really be my Plus Net static Ip address)
Y-CAM = http://MYIP:8150
SWANN = http://MYIP:3100
For the person who helps me solve this I am offering a cash reward - no seriously I am
![Smiley Smiley](/html/@39650D28FE4EA73A5BA77CFD0A477003/images/emoticons/smiley.gif)
Re: CASH REWARD - CCTV - RTP/RTSP and other issues
18-02-2012 2:41 PM
Richard.
18-02-2012 2:57 PM
I then tried swapping the web and media ports values around, I went to work the next day and still it tells me Failed Login.
Now the Swann has just Media port and Web port but the Y-CAM has
HTTP/RTSP port and a RTP port.
Then in the UPnP there is also
External HTTP/RTSP port and External RTP port
I am sure that is probably very simple but it is now doing my head in
![Sad Sad](/html/@5863905B9AC6EE4F2B28C1A2965ABC0C/images/emoticons/sad.gif)
My quote about a cash reward was a serious one so who ever solves it for me will get a PayPal or cash donation
18-02-2012 3:28 PM
18-02-2012 3:29 PM
18-02-2012 3:49 PM
The fact that the Y-CAM and Swann use different values shouldn't be a problem since both of them are using UPnP to get the router to forward the correct ports.
As far as I can see, if you set the Swann Web port to 8150 and the Media port to 30000 then its the same as the Y-CAM. I can't really see why its default ports don't work though, unless there is a clash with either the PlusNet firewall or some service on the router ( assume TG585 ? ).
Quote How do I get the equivalent Y-CAM ports into the Swann system so that i can use that instead. All this RTP and RTSP ports on the Y-CAM has got me lost.
07-03-2012 7:52 PM
Anyway, I have a TGT585 modem and I have currently got the cameras set as follows
System | Web Port | Media Port | External HTTP/RTSP port range | External RTP port range | Results | Date Tried |
Y-CAM | 8151 | 30000 | Works OK | 7/3/2012 | ||
Swann | 80 | 8150 | Login fails | 7/3/2012 |
I figured that if I put it up as a table it will be easier to track what we have tried.
The offer of the reward still stands.................
07-03-2012 8:48 PM
3Mb FTTC
07-03-2012 9:30 PM
I want to be able to use the Swann system from work as it gives me more cameras to view. So thats the basics
07-03-2012 9:49 PM
07-03-2012 9:51 PM
07-03-2012 10:10 PM
07-03-2012 10:16 PM
