View my Usage - Has it stopped working?
- Feedback
- Plusnet Feedback
- Re: View my Usage - Has it stopped working?
26-05-2014 12:10 AM
Quote from: TheArbiter1985 Padath, your comment is inappropriate - if you have a problem with your account then you can deal with it within the thread of your previous report. Making an unrelated attack here holds no logic since a fault in your account even of the same type does not affect the reliability of that of others. I would point out that my own usage monitor started up again on Tuesday which renders what you said invalid - please be more constructive when posting.
I hardly think my comment was inappropriate. The title of this thread is "View my Usage - Has it stopped working?" and I haven't been able to view my usage for more than 8 months. For all I know, these issues could be related but it appears that there is more than one problem with the usage monitor.
I'm glad to hear that you are all right and your usage monitor has started up again. Good for you.
26-05-2014 4:00 PM
They said that as I'm on Unlimited I don't really need it anyway lol
27-05-2014 11:29 AM
Quote from: dbmab2 I have had "Sorry there is nothing to show at the moment" since February and despite reporting the problem twice nothing seems to happen, should i still get a e/m reminder after i have used 8GB or not, or can i take it for granted my package as gone from value 10GB to unlimited without asking for it.?because of this problem...
Could you login to your router and make sure your username is 'yourusername@plusdsl.net'?
@IanSn @Southken
If you try a disconnect/reconnect then your usage should start to appear, any period showing 0KB will stay that way, so what your current usage total is showing is the one we are going off.
27-05-2014 4:40 PM
Thanks!
![Smiley Smiley](/html/@39650D28FE4EA73A5BA77CFD0A477003/images/emoticons/smiley.gif)
27-05-2014 6:46 PM
I thought I better report that mine "View my Usage" has now started to work without resetting the modem/router. I assume that figures showing are correct.
Hopefully, everyone else are now getting their usage through Member Centre.
Best wishes,
27-05-2014 8:08 PM
28-05-2014 10:10 PM
28-05-2014 10:39 PM
podam
30-05-2014 9:05 AM
30-05-2014 9:12 AM
31-05-2014 6:44 AM
but was reset on 29th May, so I have 15-28th May (2.4 Gb used_ and now 29th May- 14th June
(416Mb used to date)
BTW My15 Mar-15 Apr Usage seems to have skyrocketed to nearly 12 Gb. Way more than
I normally use. Was there a problem then where usage figures were over clocked? If so
then I don't think I should have been charged the extra £5 on my bill. Perhaps someone at PlusNet
could look into thid......
31-05-2014 9:41 AM
It would almost be easier for Plusnet to abandon usage quotas entirely....
31-05-2014 11:45 AM
31-05-2014 4:08 PM
31-05-2014 5:55 PM
plain ADSL, FTTC1 -40Mbps and FTTC2-80Mbps,
I'm wondering whether this might not be the time to migrate all the various old ADSL legacy accounts en masse onto the new tariffs
at some discount rate for a period to the full charge.
- Feedback
- Plusnet Feedback
