Upgraded to Fibre using TPLink D2
nerual
We are meant to switch to fibre today although our Internet is still up with no changes so not sure when/what/if happens now
I opened to keep our router and not receive the Plusnet one.
It's a TPLink D2 Archer, and "should" work but some posts mention plugging a modem into WAN port 4 others just say change the type and reset
Do I need a Modem to make this work or can it just run via the current connection to the phone line.
Will I get notification or will the Internet just go off and then I have to swap settings?
Thanks and sorry if it's been asked before I did try looking
8 REPLIES 8
Fixes: 1,485
Re: Upgraded to Fibre using TPLink D2
Moderators Note
This topic has been moved from Fibre to My Router
Fixes: 1,485
Assuming this is your router https://www.tp-link.com/uk/home-networking/dsl-modem-router/archer-d2/ you will need an VDSL modem to plug into the TP-Link as it only has an ADSL modem built in.
nerual
That's what I was thinking but their site shows VDSL connection from the phone line
So assuming I need a new router, what should happen with the change over?
Fixes: 1,485
simply, it won't work.
You don't need to buy a new router - just a modem as ethernet port 1 can be turned into a wan port.
nerual
Thanks for the cost as easy to get a new router
Look forward to going black while I wait for Amazon to deliver :0
markhawkin
Seasoned Pro
Fixes: 12
@nerual
Personally I would bet on Amazon delivering your new router before Openreach upgrade your line.
It seems the activation email is more like Openreach scheduling the job than completing the job.
The "free" Plusnet router can be used in conjunction with your TP Link device although that isn't ideal.
nerual
@markhawkin wrote:
@nerual
Your were not wrong Smiley
Was a little miffed I had to call to find out that this was the case, had not had notification it would be delayed. Moved from 16th to 25th
Just bought a couple of new routers and upgraded the outside wifi at the same time.
smoothpainting
A little late but another option would’ve been to purchase a VDSL modem such as the Draytek 130 (https://www.draytek.co.uk/products/business/vigor-130) and connect this to the WAN port on your router.
I’ve been using it for the past year and it’s rock soiled.
