Different Router
FIXEDTopic Options
- My Router
- Different Router
28-04-2019 3:30 AM
Hi
Has anyone had any experience of using the Fritzbox 3490 on the Plusnet Broadband.
I have it working on AAISP.
I’m just enquiring if I need to change any of the settings apart from the Username & Password.
Fixed! Go to the fix.
Message 1 of 3
(971 Views)
2 REPLIES 2
Re: Different Router
28-04-2019 11:33 AM
I don't know about AAISP but the settings you need for Plusnet are here: https://www.plus.net/help/broadband/broadband-connection-settings/
If necessary do a factory reset on the Fritzbox and set it up from scratch.
28-04-2019 5:16 PM
Thanks for the information.
Message 3 of 3
(915 Views)
