Plusnet Hub One - Firmware update
Bashy123
Hi Plusnet community, I've had a Plusnet Hub One for the last year or so but I've never actually been provided with an update to my router. This hasn't ever been an issue but I have recently set up a Steam Link in my house and it appears to struggle a little with stuttering.
Would it be possible for the latest firmware to be pushed out to my router please? I am currently using...
  • Firmware Version: 4.7.5.1.83.8.226 Last updated Unknown
16 REPLIES 16
OskarPapa
Fixes: 65
Re: Plusnet Hub One - Firmware update
Hi @Bashy123, thanks for your post.
In order to get a manual update pushed out, we'd recommend posting here, where our resident router king will be able to pick up your post and arrange for that update.
If you need anything else at all, please let us know.
bobpullen
Fixes: 316
@Bashy123, that's a really old firmware build which suggests there's some problem communicating with your router. I've re-registered the device at this side. Are you able to carry out a factory reset by inserting something into the pinhole at the rear of the device until the status light flashes green?
Hopefully within a day or two of doing this, you'll see the newest firmware build pushed to you.
Bashy123
Hi Bob,
I will happily do this when I am home from my work tonight. Is there an easy way for me to export my tcp/udp mappings/DMZ/any other settings to reimport once the update is done? Or should I just take a note of what I've done and re-apply once the update has been pushed through?
bobpullen
Fixes: 316
I would wait until the update is complete before reimporting/reconfiguring any of your settings. It could be something specific to your config that's blocking the communication.
If you give me a nudge once the factory reset is complete then I may be able to force things through earlier to minimise the inconvenience.
Bashy123
Hi Bob,
I've just completed the Factory Reset of my router now. I couldn't see the button on the back/top or bottom but I have done this through the Plusnet Hub Manager. Please let me know if you are able to push this through to me, thanks.
bobpullen
Fixes: 316
Thanks, your router's going for a reboot now to apply the update.
Bashy123
Hi Bob,
Thanks, that looks as though this is now running Firmware 4.7.5.1.83.8.263, which I assume is the newest version available for my router. I will test to see if this has resolved my issue.
Thank you
linnyuk
HI
Could I please get the latest update pushed to my router.
I'm currently on 4.7.5.1.83.8.226.
RandallFlagg
Fixes: 75
Hi @linnyuk - Thanks for getting in touch. I've requested this for you and our Products team should have this completed within the next 2/3 working days.
Best wishes
Dave
linnyuk
Thanks a lot Dave.
Cheers
linnyuk
Hi Dave
The update has still not been pushed out to me.  Could you please look into this further for me.
Fixes: 1,602
Hi @linnyuk
As it looks like you're on a very old firmware version I've re-added your router onto the hardware component on your account and I'd now recommend doing a factory reset of your router by pushing a paperclip into the reset pinhole at the back for 20 seconds. You should then see the firmware update within 48 hours.
linnyuk
Thanks Anoush.  I've reset my router so will look out for it updating.
Cheers
Fixes: 1,602
Cool.
Let us know how it goes.
