BT Smarthub
- My Router
- BT Smarthub
BT Smarthub
14-05-2019 12:56 AM - edited 14-05-2019 1:07 AM
I just placed an order to upgrade my existing Plusnet broadband to fibre, and today my new Plusnet hub arrived. However, as I'm currently using a fairly new BT Smart hub (or home hub 6), which I believe is fttc compatible, I'm wondering if there's any reason I can't continue to use it? It gives me great coverage in a large house with thick walls, so I'm reluctant to change for the sake of it.
Am not sure if the change to fibre will just happen, or if I need to reset something - instructions given to me so far have been rather vague. I'm still getting just 18Mb/s, so assume I'm not yet on fibre. Is there any way of telling?
Re: BT Smarthub
14-05-2019 1:49 AM
No, there's no reason why you can't
It should just switch over once the connection is moved over to fibre
(the connection itself would drop, so a reboot of the router may be needed?)
At the moment, I'd guess to say it states BT Broadband on the second section down on this page. Once the switch takes place it would more than likely change to BT Infinity.
You should get an email or text once the work at the cabinet is complete, more than likely the same message you get when you first joined - your phone line is ready and your broadband is ready. Even if you don't get these messages, the router flashing purple (during the time the line is being switched) and then the blue light would be a visual reference.
(keep the hub one for a rainy day, but only a very very wet day)
Re: BT Smarthub
14-05-2019 8:09 AM
Moderators Note
This topic has been moved from Fibre to My Router
Re: BT Smarthub
14-05-2019 10:45 AM
