Hub 2 Query
pvmb
Hub 2 Query
I have a Plusnet Hub 2 router. The connection Status reached from the router's Home page gives you basic information about broadband connection, including BB speed. But the default does not give you SNRM figures.
Out of curiosity I just logged in to the router to go through Advanced Settings and check the SNRM figures. I can remember doing this previously with this router. I can't find them! The router's Status page remains as the default just showing basic information: "This is a quick overview of your Plusnet Hub's status."
Anyone know why this is so, has there been a change to the original Hub 2 router firmware that changes this? Or am I doing something wrong?
Firmware version: v0.10.00.04201-PN
Firmware updated: 30-Jun-2023
2 REPLIES 2
Mustrum
Fixes: 77
Re: Hub 2 Query
Have a look at the technical log..
pvmb
Re: Hub 2 Query
Yes, thanks! I just logged on to report that I had found the details for myself in the Technical Log. Shows how long it has been since I logged on to look. Or it shows my age...
