P&P charge should not be on renewal
joe_yeoman
My account is due for renewal soon, but the precontract information shows a one-time charge for postage and packing. That charge should not exist as the renewal is online only.
How do I get the charge removed... and stop being applied to more online renewals
One-off charges P&P fee £6.99
5 REPLIES 5
Legend
Fixes: 259
Re: P&P charge should not be on renewal
@joe_yeoman Can you provide a screenshot showing this - as you say, it would only apply if you opted for a new/replacement Hub.
joe_yeoman
@jab1 thanks for the reply. Here's a screenshot...Screenshot_20230118-113028.png
Mustrum
Fixes: 77
@joe_yeoman   it is the charge for the new router. It does not matter it was an online renewal, it is just the standard new router charge.
Legend
Fixes: 259
And to follow from @Mustrum 's post, if you don't need/want one, then it will not apply.
Fixes: 162
Click the "change this" link to remove the Hub Two from your order.
There is no obligation to use Plusnet's free Hub Two router, but if YOU chose to do so, there is a P&P fee.
