123 Call charge on bill
drewbaxter123
I can see this seems to be a recurring issue but I have been billed for a call I did not make. I do not use the landline.
It was on 01/09/23 at 08:22 to 123 with call length 0:00:01. Cost £0.50
Can I be reimbursed as I didn't make this call. In the future will disconnecting my landline phone help or can this just happen randomly?
Thanks for any help.
3 REPLIES 3
Fixes: 410
Re: 123 Call charge on bill
No it won't I'm afraid. Its caused by Openreach engineers ( usually contractors ) working at the cabinet and dialling 123 to test lines. They should NOT be using 123, they have a specific engineering number they should be using , but 123 is easier!!!
ClaudiaG23
Fixes: 23
Hi @drewbaxter123  is this exactly what @MisterW  has said. This is the number the engineers use to test the line. Sometimes this happens if there is a cross line issue as well, however I've run the test and not ringing a fault.
I've popped a ticket on to your account about your bills. You can view this here https://www.plus.net/wizard/?p=view_question&id=236644837
 Claudia Garner
Legend
Fixes: 259
@ClaudiaG23 It may be the number some of them use - but it is not the correct one.
