Nuisance Call Open Season?
- Home Phone
- Re: Nuisance Call Open Season?
03-10-2015 12:00 PM
I know that this is a perennial problem but cannot understand why there isn't a simple fix to nip it in the bud. For instance since applying PN's server side email spam filters I get virtually no spam email at all. If it is possible for email then why not with phone calls? Blocking calls for which the number is withheld poses a problem however as certain friends and relations' numbers also come up as 'withheld' presumably because they are also ex-directory.
0203 1988103 has called three times in the last 24 hours with just the disconnected tone on answering ( at 14:31-02/10/15, 08:44-03/10/15 & 10:06-03/10/15). I have just filed a complaint with Ofcom about this number but won't hold my breath for a solution as there are numerous references online to the self same number, all bad.
01600 469009 called at 11:52-02/10/15 when I was out but I managed to link it with a financial services compensation scheme via a web search.
Then at 11:13 today 03/10/15 I had a very disturbing call from someone with a heavy Asian accent on a 'Withheld' call. I didn't catch the name of the company he was purportedly representing but he said it was a 'Legal Call' and he knew my full name and address.
![Shocked Shocked](/html/@0AB4C7C43827ACF5B296F730FEC5B1DE/images/emoticons/shocked.gif)
It's bad enough when I answer the phone myself but as I have my elderly parents living at my address - both in their 80s - I am concerned that they might feel intimidated by this type of call, and would ideally like to put a stop to them once and for all.
Any suggestions Plusnet?
03-10-2015 12:41 PM
03-10-2015 12:43 PM
No, those are two different things.
Quote from: Spruance certain friends and relations' numbers also come up as 'withheld' presumably because they are also ex-directory.
Not giving out caller-id is a choice that can be made, not sure why you would do it though, but can be overridden per call by dialling a prefix.
Equally I believe there is a setting to reject anonymous calls. Probably costs though.
So if you invoke that rejection people call you anonymously will be rejected and have to call again adding the prefix so that their numbers are presented.
If your friend & relatives encounter this they will either get used to adding the prefix or get fed up and stop the (IMHO pointless) automatic withholding of the calling number.
As @ejs notes, calling numbers can easily be faked by scammers.
03-10-2015 1:06 PM
In the meantime I've done some research and have found a BT phone product (BT 8500) that might do the trick. If it works it might be the solution.
03-10-2015 5:09 PM
There are several handsets offering this now, but the CPR has been very handy to block 99% of the spam calls for me.
03-10-2015 8:59 PM
I have this product (recommended by someone on here) and can thoroughly recommend it myself. Our nuisance calls have almost stopped.
05-10-2015 1:53 AM
You can choose what you want to happen for different categories of calls. For example, I have witheld numbers go straight to the answering machine so if it is a relative or something, they can still at least leave a message. That is just the tip of the iceberg, there are loads more features on it. I can't recommend it highly enough. I can even log into a web portal when I am travelling and see a list of all incoming and outgoing calls without even having to call home. The web portal will let me know if anyone left a message then I can call in to the answering machine.
It has virtually eliminated spam calls.
05-10-2015 12:19 PM
05-10-2015 1:26 PM
I was also getting these 02 & 01 numbers calling me,with this phone it is very easy to block them.
![Grin Grin](/html/@D40767E4EBB99989487344F3E42E44B1/images/emoticons/grin.gif)
![Cheesy Cheesy](/html/@69488338D0B3891CC5F8AEAEEB30C648/images/emoticons/cheesy.gif)
![Smiley Smiley](/html/@39650D28FE4EA73A5BA77CFD0A477003/images/emoticons/smiley.gif)
05-10-2015 2:33 PM
They are on offer at amazon, to buy or not to buy .... my current panasonic phones work great just they dont have any blocking controls :S
05-10-2015 2:51 PM
- Home Phone
