BF4
- Gaming
- BF4
Re: BF4
23-04-2014 1:05 PM
Port 3569 udp not open- this happened way back and resurfaced even opening it using portforward.com it didnt work,this is server side EA/Dice ,think as there triyng to fix the netcode issue they have caused the problems
another one has been PB saying corrupt files --PB fault you can try updating etc it wont work but disappears
Also this may explain few things on BF4 bit of an eye opener
https://www.youtube.com/watch?v=5OSv5HH1egE
Re: BF4
23-04-2014 7:31 PM
Re: BF4
23-04-2014 7:53 PM
If I ever buy an EA game again it'll be second-hand.
Re: BF4
04-06-2014 2:59 AM
Re: BF4
04-06-2014 3:09 AM
Have to ask, though, have you actually set the tickrate to 30hz? I'm sure you have, but I read that it is set to off by default and you have options of off, low, medium, and high. It'll be under ''hi-frequency network update.'' If you have, are you experiencing the same with it off? What about the network smoothing factor?, do you have that at zero?
Most of the early feedback was positive regarding the changes.
Re: BF4
04-06-2014 7:50 AM
best patch ever .
still some more fixes from the CTE to come i played on the CTE what a difference from the vanilla game , problem is they should have done this 6 month ago .
Re: BF4
04-06-2014 8:52 PM
Re: BF4
04-06-2014 9:19 PM
Re: BF4
05-06-2014 12:42 PM
I don't get as much time to play as I did so when I do I most hop into metro and lockers 64p 24/7 servers for an hour or so. Maybe Il try a slower paced game next time I'm on and see if that makes any difference.
I just wanted to check it wasn't my connection causing the issues. Thanks.
Re: BF4
06-06-2014 7:46 PM
Most annoying thing for me is if I fire an RPG and I get killed my RPG vanishes, but if I kill someone their RPG keeps coming at me. Same with bullets and grenades, but the RPG is the most obvious because you can see it coming/disappear, lol.
Re: BF4
06-06-2014 10:45 PM
a lot more to come from the CTE the forums are full of good ideas they going to implement
Re: BF4
06-06-2014 11:43 PM
Re: BF4
07-06-2014 7:08 AM
but i dont know if thats due to the difference in the GFX constrain of consoles , as i have more control over mine with the PC .
on the PS4 can you not bring up the bf console and type "perfoverlay.drawfps" to check your FPS ?
Re: BF4
07-06-2014 8:16 AM
Nope, we can't do the control panel thing with the PS4 like you can with the PC version.
Since the latest patch I have noticed improvements overall, but still get killed around corners and when behind well established cover on occasions.
I even put my PS4 in a DMZ just to make sure there were no restrictions, but I have not noticed anything at all since doing it last week. See this thread here and tell me if you think I have done it correctly. http://community.plus.net/forum/index.php/topic,127782.0.html
PS should I leave UPNP on, or turn it off? There is nothing else on the network, and no one else uses it except me on the PS4 or the TV for Film Streaming etc.
Thanks.
Re: BF4
07-06-2014 8:37 AM
