New connection
- Full Fibre
- New connection
Re: New connection
11-05-2012 9:52 AM
Re: New connection
11-05-2012 10:37 AM
It's probably worth raising another fault I'm afraid, we can't do anything to change the profiles and your upload has dropped to 800k though I can't see any reason for it.
If you could run through the faults wizard (http://faults.plus.net) we'll get it raised and sorted. Sorry about the hassle.
Re: New connection
11-05-2012 11:27 AM
Re: New connection
11-05-2012 1:07 PM
i never clicked anything has someone already done this for me ?
Re: New connection
11-05-2012 1:43 PM
Re: New connection
11-05-2012 5:59 PM
Re: New connection
12-05-2012 7:30 AM
have just received a email from PN my question has been escalated but was amazed that was asked to use the BT beta tester for speed tests ? "other speed testers often don't have the bandwidth to report the speed correctly."
the beta tester says "BT Wholesale will not accept any line speed faults from Communications Providers based on the output of this Beta Speed Tester."
so anyhow i tried it , not much difference from speedtest.net ?
Re: New connection
12-05-2012 4:22 PM
and for some reason i still cannot get the troubleshooter to run
Re: New connection
14-05-2012 1:17 PM
Re: New connection
14-05-2012 1:26 PM
Re: New connection
14-05-2012 4:40 PM
all i see is this , or is there summat i am missing
Re: New connection
14-05-2012 5:19 PM
Re: New connection
14-05-2012 5:27 PM
Re: New connection
15-05-2012 11:03 AM
Just made a couple of changes to your account and have hopefully cleared the issue with the faults wizard - any chance you could try that one again? Hopefully it'll let you raise one this time.
Re: New connection
15-05-2012 11:49 AM
It has worked now
