FTTP off and on every 15 mins or so
- Full Fibre
- Re: FTTP off and on every 15 mins or so
08-01-2014 12:07 PM
My FTTP appears to be disconnecting and reconnecting all the time. Seems to be getting worse. Both the router's connection to the FTTP drops and also the wireless signal from the router vanishes. Is this a symptom of a faulty zyxel router?
I've looked at the router logs and there is nothing obviously wrong.
What normally happens is that on my 3 devices I notice wifi has disconnected, soon as I reconnect it says limited service e.g. no internet but connected to router OK, and then after a very short while I get internet access back.
Works ok for a while and then rinse and repeat
Any ideas?
Any ideas?
Message 1 of 8
(6,470 Views)
7 REPLIES 7
08-01-2014 12:37 PM
What are the ONT lights doing?
Message 2 of 8
(898 Views)
08-01-2014 1:00 PM
No idea as I have a bookcase in the way. I will have to video it
Message 3 of 8
(898 Views)
08-01-2014 4:33 PM
Quote from: AndyH What are the ONT lights doing?
All are normal, with PON light on steady, port 1 that is connected to the zyxel is flashing with traffic and power light is on.
Likewise, nothing odd occurs on the zyxel with the power light on, internet LED on and WIFI LED on
I can see the WAN status on the zyxel admin page go down and up though.
Message 4 of 8
(898 Views)
08-01-2014 4:37 PM
It could be the router is on the way out...have you tried resetting the router or updating the firmware (if newer is available)?
Message 5 of 8
(898 Views)
08-01-2014 4:42 PM
yes firmware was checked a couple of weeks ago and I have powered of all kit for 30 mins last weekend, I may have another router here I can try now that I've thought about it!
adie:quote
adie:quote
Message 6 of 8
(898 Views)
08-01-2014 6:20 PM
It's definitely worth trying another router if you have one.
What does it say in the router log when you lose connection?
Message 7 of 8
(898 Views)
08-01-2014 7:05 PM
Got the new router plugged in now thanks. Will keep an eye out on reliability
There's nothing in the routers logs showing disconnects/drops or reconnects. Every couple of seconds it justs puts in information message up saying "WAN, start TR-Agent" - no idea what that is, google is not much help either.
adie:quote
adie:quote
Message 8 of 8
(898 Views)
- Full Fibre
