how do i upgrade to fibre extra
- how do i upgrade to fibre extra
30-08-2015 12:01 PM
hi i want to upgrade to fibre extra but all i get is this There's something we should mention...
You can't change your products for the moment, you have an order which is currently being processed. Please try again later.
If you find you can't change your products again, let us know using the Help Assistant.
then it says i can change it but then back to this error and ive tried to chat online but why when asked to type what i want to ask them it gets deleted and i get how can they help ?also speeds are less than half so as ive just joined would it be easier to go elsewhere as ive never had problems with speeds when using other companies who only use one router never had open reach modem+a router thats only reason why i asked would it be easier to go elsewhere thanks
Message 1 of 3
(693 Views)
2 REPLIES 2
Re: how do i upgrade to fibre extra
30-08-2015 10:58 PM
1.5mbs download bt wifi fon is faster just pain in the arse falling out of the window but its free and faster but just as helpfull as plusnet oh your too ill put routers in the bin no ones going to pinch them
Message 2 of 3
(447 Views)
31-08-2015 11:34 AM
Message 3 of 3
(447 Views)
