Can I get Unlimited Fibre Extra ?
- Can I get Unlimited Fibre Extra ?
28-08-2015 10:38 AM
I see that Unlimited Fibre Extra is an option with PlusNet but I can't find any info on it? Can I get it in my area???
Message 1 of 5
(872 Views)
4 REPLIES 4
Re: Can I get Unlimited Fibre Extra ?
28-08-2015 10:47 AM
See what this says when you put in your phone number http://www.dslchecker.bt.com/adsl/ADSLChecker.TelephoneNumberOutput
Message 2 of 5
(558 Views)
28-08-2015 7:38 PM
Be warned that plusnet go by the lowest figure in your estimate range so even though the highest figure in the range will say you can get the extra package if your lowest figure is below 40Mb you will be told you cant get it.
Message 3 of 5
(558 Views)
31-08-2015 2:17 PM
Message 4 of 5
(558 Views)
31-08-2015 2:21 PM
But if the link provided by OldJim says your upload could be faster than 2Mbps (and that is important for you) your only option is to find a different ISP who will provide you with an up to 40 down, up to 10 up service (e.g. BT).
Message 5 of 5
(558 Views)
