Trying to set up my Asus DSL-N66U and failing
- Trying to set up my Asus DSL-N66U and failing
19-03-2015 4:32 PM
Hi, after connecting up the modem (replacing both plusnet sent me) and running the quick setup guide and choosing uk and plusnet I get no internet
Is there anything that I can try? This modem is a bit over my head.
Message 1 of 9
(1,783 Views)
8 REPLIES 8
Re: Trying to set up my Asus DSL-N66U and failing
19-03-2015 5:06 PM
Message 2 of 9
(1,034 Views)
19-03-2015 5:09 PM
Which ones specifically?
dick:quote
dick:quote
Message 3 of 9
(1,034 Views)
19-03-2015 5:10 PM
This post may help you set up the DSL-N66u
http://community.plus.net/forum/index.php/topic,134288.0.html
ex-Plusnet (ADSL, FTTC) 2008-2023. now BT (FTTP) 2023-
Message 4 of 9
(1,034 Views)
19-03-2015 5:52 PM
That didn't help, the only setting I needed to change was ipv4 to ipv4/6 and it didn't work.
dick:quote
dick:quote
Message 5 of 9
(1,034 Views)
19-03-2015 7:37 PM
Does the DSL light stay on, and have you checked the log for clues?
See also
http://community.plus.net/forum/index.php/topic,135704.0.html
http://community.plus.net/forum/index.php/topic,121820.0.html
fwiw, I would have continued to use openreach modem if that worked well, and just buy a RT-N66U.
See also
Message 6 of 9
(1,034 Views)
19-03-2015 8:10 PM
FWIU, the DSL version of this router has been known to have issues, however, i thought these were sorted with a firmware update?
Message 7 of 9
(1,034 Views)
20-03-2015 11:48 AM
The DSL light does stay on (my internet worked before the firmware update). I'll upload the log when I re-connect the modem
Message 8 of 9
(1,034 Views)
25-03-2015 5:44 PM
OK this is bizzare, I connected the modem to copy the log and it just works... I didn't do anything at all it just works.
Here's the log anyway, does everything look normal?
2010-12-31 16:01:03 syslogd started: BusyBox v1.00 (2015.02.25-11:56+0000)
2010-12-31 16:01:03 WAN Connection: Ethernet link down.
2010-12-31 16:01:04 kernel: RTS debug message OFF!
2010-12-31 16:01:04 kernel: log cicmd 0 (wan dmt2 set largeD 2 )
2010-12-31 16:01:04 kernel: usbcore: registered new interface driver usbfs
2010-12-31 16:01:04 kernel: usbcore: registered new interface driver hub
2010-12-31 16:01:04 kernel: usbcore: registered new device driver usb
2010-12-31 16:01:04 kernel: SCSI subsystem initialized
2010-12-31 16:01:05 stop_nat_rules: apply the redirect_rules!
2010-12-31 16:01:05 kernel: Initializing USB Mass Storage driver...
2010-12-31 16:01:05 kernel: usbcore: registered new interface driver usb-storage
2010-12-31 16:01:05 kernel: USB Mass Storage support registered.
2010-12-31 16:01:06 miniupnpd[1942]: upnp_event_process_notify: connect(192.168.1.3:2869): Connection reset by peer
2010-12-31 16:01:06 kernel: ufsd:: trace mask set to 0000000f
2010-12-31 16:01:06 kernel: ufsd: driver (UFSD_HEAD lke_8.9.0_r209178_b9, LBD=ON, acl, ioctl, sd, wb, tr) loaded at c02ee000
2010-12-31 16:01:06 kernel: NTFS support included
2010-12-31 16:01:06 kernel: Big endian platform
2010-12-31 16:01:06 kernel: optimized: speed
2010-12-31 16:01:06 kernel: Build_for__ASUS_PRODUCTS_001_k2.6.22.15_2012-12-24_lke_8.9.0_r209178_b9
2010-12-31 16:01:07 kernel: PCI: Enabling device 0000:02:03.3 (0000 -> 0002)
2010-12-31 16:01:07 kernel: ehci_hcd 0000:02:03.3: EHCI Host Controller
2010-12-31 16:01:07 kernel: ehci_hcd 0000:02:03.3: new USB bus registered, assigned bus number 1
2010-12-31 16:01:07 kernel: ehci_hcd 0000:02:03.3: irq 21, io mem 0x1fba1000
2010-12-31 16:01:07 kernel: ehci_hcd 0000:02:03.3: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
2010-12-31 16:01:07 kernel: usb usb1: configuration #1 chosen from 1 choice
2010-12-31 16:01:07 kernel: hub 1-0:1.0: USB hub found
2010-12-31 16:01:07 kernel: hub 1-0:1.0: 2 ports detected
2010-12-31 16:01:09 kernel: PCI: Enabling device 0000:02:03.0 (0000 -> 0002)
2010-12-31 16:01:09 kernel: ohci_hcd 0000:02:03.0: OHCI Host Controller
2010-12-31 16:01:09 kernel: ohci_hcd 0000:02:03.0: new USB bus registered, assigned bus number 2
2010-12-31 16:01:09 kernel: ohci_hcd 0000:02:03.0: irq 24, io mem 0x1fba0000
2010-12-31 16:01:09 kernel: usb usb2: configuration #1 chosen from 1 choice
2010-12-31 16:01:09 kernel: hub 2-0:1.0: USB hub found
2010-12-31 16:01:09 kernel: hub 2-0:1.0: 2 ports detected
2010-12-31 16:01:09 kernel: usbcore: registered new interface driver usblp
2010-12-31 16:01:09 kernel: drivers/usb/class/usblp.c: v0.13: USB Printer Device Class driver
2010-12-31 16:01:10 kernel: set cicmd 5
2010-12-31 16:01:10 kernel: 1: wan vdsl2 set sra on
2010-12-31 16:01:10 kernel: new sra = on
2010-12-31 16:01:10 kernel: 2: wan vdsl2 set target_snrm 32767
2010-12-31 16:01:10 kernel: new target_snrm = 32767
2010-12-31 16:01:10 kernel: 3: wan vdsl set tx_gain_off 32767
2010-12-31 16:01:10 kernel: new_tx_gain_offset = 32767
2010-12-31 16:01:10 kernel: 65535 65535 65535 65535
2010-12-31 16:01:10 kernel: new agc_ref = 65535,65535,65535,65535
2010-12-31 16:01:10 kernel: 5: wan vdsl set upbo 255
2010-12-31 16:01:10 kernel: cur upbo =1
2010-12-31 16:01:10 kernel: usage: wan vdsl2 set upbo [on|off]
2010-12-31 16:01:10 kernel: usbcore: registered new interface driver asix
2010-12-31 16:01:10 kernel: usbcore: registered new interface driver cdc_ether
2010-12-31 16:01:10 kernel: usbcore: registered new interface driver rndis_host
2010-12-31 16:01:11 kernel: cdc_ncm: 14-Mar-2012
2010-12-31 16:01:11 kernel: usbcore: registered new interface driver cdc_ncm
2010-12-31 16:01:11 kernel: usbcore: registered new interface driver cdc_wdm
2010-12-31 16:01:11 kernel: cdc_mbim: loaded
2010-12-31 16:01:11 kernel: usbcore: registered new interface driver cdc_mbim
2010-12-31 16:01:11 rstats[2357]: [start rstats]
2010-12-31 16:01:17 kernel: br1: topology change detected, propagating
2010-12-31 16:01:17 kernel: br1: port 1(eth0.12) entering forwarding state
2010-12-31 16:01:23 WEB: WEB user <admin> login
2010-12-31 16:01:28 kernel: tc3262_ptm_close
2010-12-31 16:01:28 syslog: error receiving pppoe packet: Network is down
2010-12-31 16:01:30 WAN Connection: Fail to connect with some issues.
2010-12-31 16:01:31 kernel: tc3262_ptm_close
2010-12-31 16:01:31 kernel: nas8: starting interface.
2010-12-31 16:01:32 syslog: Initialize LCP.
2010-12-31 16:01:32 syslog: Plugin libpppoe.so loaded.
2010-12-31 16:01:32 syslog: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.5
2010-12-31 16:01:32 syslog: pppd 2.4.5 started by admin, uid 0
2010-12-31 16:01:32 syslog: LCP is allowed to come up.
2010-12-31 16:01:32 kernel: Link State: DSL link up.
2010-12-31 16:01:33 dnsmasq[2762]: started, version 2.52 cachesize 150
2010-12-31 16:01:33 dnsmasq[2762]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-I18N no-DHCP no-TFTP
2010-12-31 16:01:33 dnsmasq[2762]: reading /etc/resolv.conf
2010-12-31 16:01:33 dnsmasq[2762]: ignoring nameserver ::1 - local interface
2010-12-31 16:01:33 dnsmasq[2762]: ignoring nameserver 127.0.0.1 - local interface
2010-12-31 16:01:33 dnsmasq[2762]: read /etc/hosts - 4 addresses
2010-12-31 16:01:48 syslog: PPP session is 90
2010-12-31 16:01:48 syslog: Connected to 00:30:88:00:00:04 via interface nas8_0
2010-12-31 16:01:48 syslog: Using interface ppp80
2010-12-31 16:01:48 syslog: Connect: ppp80 <--> nas8_0
2010-12-31 16:01:49 syslog: CHAP authentication succeeded
2010-12-31 16:01:49 syslog: CHAP authentication success
2010-12-31 16:01:49 syslog: peer from calling number 00:30:88:00:00:04 authorized
2010-12-31 16:01:49 syslog: local IP address 46.208.190.216
2010-12-31 16:01:49 syslog: remote IP address 195.166.130.139
2010-12-31 16:01:49 syslog: primary DNS address 212.159.6.10
2010-12-31 16:01:49 syslog: secondary DNS address 212.159.6.9
2010-12-31 16:01:49 dnsmasq[2762]: exiting on receipt of SIGTERM
2010-12-31 16:01:49 dnsmasq[2924]: started, version 2.52 cachesize 150
2010-12-31 16:01:49 dnsmasq[2924]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-I18N no-DHCP no-TFTP
2010-12-31 16:01:49 dnsmasq[2924]: using nameserver 212.159.6.9#53(via ppp80)
2010-12-31 16:01:49 dnsmasq[2924]: using nameserver 212.159.6.10#53(via ppp80)
2010-12-31 16:01:49 dnsmasq[2924]: reading /etc/resolv.conf
2010-12-31 16:01:49 dnsmasq[2924]: ignoring nameserver ::1 - local interface
2010-12-31 16:01:49 dnsmasq[2924]: ignoring nameserver 127.0.0.1 - local interface
2010-12-31 16:01:49 dnsmasq[2924]: read /etc/hosts - 4 addresses
2010-12-31 16:01:51 kernel: Link State: PVC_8_0 logistic interface up.
2010-12-31 16:01:51 WAN Connection: WAN was restored.
2010-12-31 16:01:51 start_nat_rules: apply the nat_rules(/tmp/nat_rules)!
2010-12-31 16:01:52 kernel: ddns_execute(), DDNS is not enable, so remove /etc/ddns.conf.
2010-12-31 16:01:53 dnsmasq[3222]: started, version 2.52 cachesize 150
2010-12-31 16:01:53 dnsmasq[3222]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-I18N no-DHCP no-TFTP
2010-12-31 16:01:53 dnsmasq[3222]: using nameserver 212.159.6.9#53(via ppp80)
2010-12-31 16:01:53 dnsmasq[3222]: using nameserver 212.159.6.10#53(via ppp80)
2010-12-31 16:01:53 dnsmasq[3222]: reading /etc/resolv.conf
2010-12-31 16:01:53 dnsmasq[3222]: ignoring nameserver ::1 - local interface
2010-12-31 16:01:53 dnsmasq[3222]: ignoring nameserver 127.0.0.1 - local interface
2010-12-31 16:01:53 dnsmasq[3222]: read /etc/hosts - 4 addresses
Message 9 of 9
(1,034 Views)
