Fiber Speed Query
- Fiber Speed Query
Fiber Speed Query
25-03-2015 2:33 PM
Ok, first thing, this is my first forum post so apologies for any failures in etiquette.
i had my fiber fitted over a week ago and am still not getting anywhere near the estimated speed, it was estimated i would get 32.5 but i started day 1 at 8mb eventually rising to 20-21, since then its stayed there. i know from what i have read it can take up to 10 days to find its level, but theres been little if any change since it hit 20 on day 1. according to BTW speed test my ip profile is set at 21.03 which has increased from 20.5.
Is there something i should have done that i have missed?
Message 1 of 2
(526 Views)
1 REPLY 1
Re: Fiber Speed Query
25-03-2015 2:47 PM
I've just tested your line and it's showing below the estimate, it's likely to need a fault investigating. Can you check for noise on your phone line by dialling 17070, if that's clear you can open a fault with us at https://faults.plus.net
Downstream Speed 22.3 Mbps
Upstream Speed 4.7 Mbps
Profile Name 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Interleaving On
Message 2 of 2
(285 Views)
