Anyone have an update on the fault that seems to be happening?
- Re: Anyone have an update on the fault that seems ...
30-01-2015 9:45 PM
Our FTTC router's been unable to connect for the last few hours - presumably due to this: http://usertools.plus.net/status/archive/1422641789.htm
It appears to be unable to authenticate.. continually retrying with the following in the logs:
Connect: ppp0 <--> vlan100
CHAP authentication failed
Connection terminated
Every so often it seems to manage to connect to something, logging CHAP authentication succeded - but this doesn't seem to result in working internet access, presumably due to connecting on vlan 100?
http://usertools.plus.net/status/archive/1422641789.htm suggested an update would be posted at 20:00 but nothing sems to be forthcoming. Anyone know what's going on or when it's likely to be fixed?
Message 1 of 2
(544 Views)
1 REPLY 1
Re: Anyone have an update on the fault that seems to be happening?
31-01-2015 9:39 AM
I've posted about this over here: http://community.plus.net/forum/index.php/topic,136290.msg1196208.html#msg1196208
Message 2 of 2
(243 Views)
