keywords
- Everything else
- keywords
keywords
13-07-2009 12:55 PM
Can somebody kindly direct me to an idiots guide to adding keywords to a plusnet web space to try and encourage visitors?
Many thanks,
Stewart
Many thanks,
Stewart
Message 1 of 4
(1,110 Views)
3 REPLIES 3
Re: keywords
13-07-2009 1:01 PM
Easy answer is like this taken from index.html on my wife's site
<meta name="keywords" content="artist, mixed media, acrylic, Joan Scott, Dorset, original artworks, abstract, semi abstract">
<meta name="description" content="Joan Scott, Mixed Media Artist">
Another thing is to create a Google site map http://www.xml-sitemaps.com/ add it to the website and then using a Google Acount and add it to the Google information using the webmaster tools
Message 2 of 4
(393 Views)
Re: keywords
13-07-2009 1:28 PM
I've long been taught that just using met keywords - especially long strings of them is of little value these days - they were abused and so major search engines take little or no use of them - particularly Google.
You need to put keywords in amongst the text, alts & names for images, and as page titles
look at a few of these
Googling how to use keywords
Message 3 of 4
(393 Views)
Re: keywords
13-07-2009 1:29 PM
I'd suggest that it would be a good idea to google "Search Engine Optimisation".
Message 4 of 4
(393 Views)
