How to cheat and bypass DNS propagation!
- Everything else
- How to cheat and bypass DNS propagation!
10-07-2009 2:50 PM
This may or may not already be known to some people, but after making changes to my domain I must now wait for propagation which can take up to 48 hours (worst case senario). The simple solution below will bypass ISP propagation and allow you to work on your own domain right away:
Browse to your windows HOST file located in %windir%\system32\drivers\etc
Edit this with notepad and add the following lines:
<Hosts IP Address> www.website.co.uk
<Hosts IP Address> website.co.uk
(do this without the <>)
As I have a number of domains hosted with plesk I could ping each one to ensure I have the correct IP, so my HOST file looks like:
212.56.83.200 www.mydomain.co.uk
212.56.83.200 mydomain.co.uk
and voila, it works straight away.
Message 1 of 5
(3,437 Views)
4 REPLIES 4
Re: How to cheat and bypass DNS propagation!
13-07-2009 8:40 AM
If you are only doing this for testing, why not simply type the IP address into your browser, rather than edit your hosts file, which you will have to go back and edit later to allow you to test the DNS propagation has worked?
Message 2 of 5
(1,065 Views)
13-07-2009 2:38 PM
im not sure you can? since the IP Address doesnt appear to resolve the website address?
Message 3 of 5
(1,065 Views)
13-07-2009 7:52 PM
The IP hosts 100s of websites - it's a web server, so the browser still has to send the domain name in the URL to the IP address it has found in the hosts file for the web server to resolve which of it's hosted websites you are asking for.
Just putting in the IP address will resolve to the default website on the server which will probably not show anything.
Message 4 of 5
(1,065 Views)
13-07-2009 11:07 PM
Peter has pretty much hit the nail on the head.
If the server is hosting multiple virtual hosts, then the server needs to be aware of which host it should be serving.
When your browser requests a web page, it will send a request along the lines of:
The important part is the host header. if you access just by IP address then the host header will generally not exist, or just show the IP.
B.
GET / HTTP/1.1
Accept-Language: en-us
Accept-Encoding: gzip, deflate
User-Agent: Mozilla/4.0 (compatible; MSIE
5.01; Windows NT)
Host: www.yourwebsite.com
Connection: Keep-Alive
B.
Message 5 of 5
(1,065 Views)
- Everything else
