help installing wordpress!
- Everything else
- help installing wordpress!
23-03-2010 12:30 AM
i've been struggling to install wordpress. i have so far enabled sql and cgi. i have uploaded wordpress to cgi space. and i also uploaded the script reccommended to install permissions to run the install... as mentioned in other posts on here.... now, i think this is where i have gone wrong, as when i try the wordpress install file i get this :
Server error!
The server encountered an internal error and was unable to complete your request.
Error message:
Premature end of script headers: install.php
If you think this is a server error, please contact the webmaster.
Error 500
ccgi.fforchlas.plus.com
Tue Mar 23 00:23:19 2010
Apache
can someone please help?
thank you!
Re: help installing wordpress!
23-03-2010 11:50 AM
Then follow the information given here by Gabe to set the correct permissions: http://community.plus.net/forum/index.php/topic,84349.0.html
23-03-2010 10:14 PM
yes, i have changed the config filename and tried to follow the instructions to set correct permissions as per the instructions, i'm using fetch as my ftp thingy and using a mac.... i set permissions to 700 for the whole wordpress folder.... now i get Access forbidden!
You don't have permission to access the requested object. It is either read-protected or not readable by the server.
Error 403
Tue Mar 23 22:09:36 2010
Apache
help!
24-03-2010 9:23 AM
For folders you need to set the permissions to 710, not 700, apart from your home directory which should be 1750. Gabe posted a script in here that will set the permissions correctly for you.
24-03-2010 9:33 PM
i copied the script gabe posted and called it setperms.cgi, here http://ccgi.fforchlas.plus.com/setperms.cgi
however, when i try to call it with the web browser i get this error message :
Server error!
Error message:
Premature end of script headers: setperms.cgi
Error 500
Wed Mar 24 21:30:45 2010
Apache
i know i am a beginner in all this, but all i want is to use wordpress! argh!
24-03-2010 10:46 PM
David
Edit: Correction. The suggestion above depends on which setperms.xxx file you are using. There was an older 'php' version which required the xxx extension to be php. The newer version here is a bash script and xxx must be cgi.
24-03-2010 11:35 PM
help!
25-03-2010 12:14 AM
What permissions did it set for the wp-admin folder and install.php within it?
David
25-03-2010 8:27 AM
Slight concern is how much you changed to 700 with Fetch. The last version of Fetch I saw didn't recurse permissions into folders, so setting permissions on the wordpress folder wouldn't affect its contents, but if everything in the folder and all its subfolders was in fact set to 700 then that would cause problems with serving images, etc. The setperms script won't set them back to 640, which static (non-script) content needs. Check if everything in /wordpress was set to 700 and, if it was, then probably the easiest thing to do would be to delete that upload and upload it again, then run the setperms script. If it wasn't, just run setperms.cgi.
After that it gets easier.
![Smiley Smiley](/html/@39650D28FE4EA73A5BA77CFD0A477003/images/emoticons/smiley.gif)
Gabe
25-03-2010 9:03 AM
thank you everyone!
bethan
- Everything else
