Setting up Webspace - Assistance Please
- Everything else
- Re: Setting up Webspace - Assistance Please
04-11-2009 9:11 AM
Hi All, I have put together a simple website using Kompozer and have tried to publish this to my Plusnet webspace but without success.
I have tried to follow the instruction on the website but must be doing something wrong.
In Kompozer I have set the following details in
Website Information: http://www.username.plus.com
Publishing Server: ftp://ftp.plus.net/htdocs
User name: myusename
password: my password
Any assistance/guidance greatly appreciated
Thanks Dave
Thanks Dave
Message 1 of 7
(1,677 Views)
6 REPLIES 6
04-11-2009 9:30 AM
The publishing server doesn't have the /htdocs on the end. htdocs is the name of the folder to which you have to upload the content once the ftp connection is established.
Message 2 of 7
(683 Views)
04-11-2009 10:53 AM
I'm on FOL, but I would imagine the process is the same. I publish to ftp://homepages.free-online.net/htdocs
Message 3 of 7
(683 Views)
04-11-2009 12:48 PM
or you can do it this way in your Browser for eggzampull Internet Explorer v6 put in to the Address bar: ftp://Username:your_password@ftp.plus.net/htdocs/
Message 4 of 7
(683 Views)
04-11-2009 2:41 PM
Thanks for your replies.
I have tried different things and have now progressed slightly. I have published the site but if i try and view the site it now get:
Index of /
Parent Directory
Index.html
this shows in IE when i try and go to the site.
Any ideas? Thanks
Index of /
Parent Directory
Index.html
Any ideas? Thanks
Message 5 of 7
(683 Views)
05-11-2009 7:26 AM
You must have your first page called: index.html
Plus you should have it in lower case, do not use upper case for your file extensions.
Can you give us a link to your site?
Message 6 of 7
(683 Views)
Re:Setting up Webspace - Assistance Please
06-11-2009 3:34 PM
Hi Dave,
I've taken the liberty of logging in to your webspace and renaming the index.html file as per Gary's advice above (thanks Gary). The issue was indeed that you'd capitalised the I on index.
You should now see the correct page when you browse to your site.
Hope that helps,
Hope that helps,
Message 7 of 7
(683 Views)
- Everything else
