Recommend small wikis?
- Everything else
- Re: Recommend small wikis?
19-01-2009 8:49 PM
Hi all,
I'm considering setting up a wiki on my free webspace that comes with plusnet. It will be for only me mainly and will have low traffic volumes.
Through work I have experience with Twiki and dokuwiki, but are there any others around that people have successfully installed and would recommend (and why)?
Cheers,
Chris
Cheers,
Chris
Message 1 of 4
(1,189 Views)
3 REPLIES 3
19-01-2009 9:28 PM
I have no real experience with wikis, but have a look at http.www.hotscripts.com . Plenty to choose from with user reviews and ratings
Message 2 of 4
(545 Views)
20-01-2009 4:06 PM
Thanks for the link.
I found WikkaWiki on there which looks like what I need and the installation is *very* simple
http://wikkawiki.org/HomePage
Now I just need to have a go at installing it....
Message 3 of 4
(545 Views)
21-01-2009 2:39 PM
Ok. That seemed to work well. It has an http based installer so it all works through the browser. You also need to enable MySQL and Bob's your Uncle.
Slight problem, though. The CSS isn't working. It seems as if the cgi is trying to execute it.
I'll open another thread on this.
Message 4 of 4
(545 Views)
- Everything else
