Hosting a website at home
ora8i
I have full fiber so its reasonably fast, am I allowed to run a website from home?
If so do Plusnet have any doc's or 'how to's' that would be relevant?
Thanks All.
7 REPLIES 7
Legend
Fixes: 257
Re: Hosting a website at home
I see no reason why you can't host one, but as Plusnet pulled out hosting quite some time ago, I would think there are very few staff who would know the first thing about it. I also doubt there is any documentation.
Mustrum
Fixes: 77
Champnet
Aspiring Hero
Fixes: 13
It's easy. Point your domain to your home external IP address, on the router point port at internal device running web server.  Come back if you need help......
Fixes: 420
Moderator's note:
Thread moved from Broadband to Everything Else
corringham
Seasoned Champion
Fixes: 16
I've been running web sites and mail servers from home for more than 20 years. If you have a reasonably fast connection (upload speed is perhaps more important than download speed) and a static IP address it can work well (you can do it with a dynamic address, but that has extra hoops to jump through).
The first step is to get your server set up - there are a number of different engines available, and it will depend on whether you are running on Windows or Linux, or another OS.
Then you need a domain, set up its DNS to point to your IP address, forward the appropriate ports to your server, and job done.
Do make sure your setup is secure - you will get hammered by wannabe hackers (my mail and web servers receive several thousand attempted logins and other probes every day).
greygit1
Agree 100%. Keeping the s/w patched and updated is an 'overhead' that has to be built into the decision.
ora8i
Thanks All.
I was more concerned ghat it might be prohibited  than anything else.
Ora
