IMAP problems since yesterday OUTLOOK/Mifi
Plowman
Hello,
I'm trying to set up IMAP using Microsoft Outlook.
Currently I'm using mobile broadband not my Plusnet broadband. I do have Plusnet broadband but not to hand.
I can't get it to work. I input the details and it hangs: "We're getting things ready".
IMAP settings:
Incoming server: imap.plus.net
Incoming port: 993
Encryption method: None
Require login using SPA: Uncheck
Outgoing server: relay.plus.net
Outgoing port: 587 (recommended) or 25
Encryption method: STARTTLS
Require login using SPA: Check
I telephoned support and was directed to webmail.
Are the details correct?
How can I get it to work please?
3 REPLIES 3
Fixes: 162
Re: IMAP problems since yesterday OUTLOOK/Mifi
IMAP on port 993 should have TLS/SSL encryption.
SMTP port 587 and SPA NOT checked.
Aspiring Hero
Fixes: 76
As above, the settings should look like
Plowman
Thank you.
It worked.
Much appreciated.
