super user password 585 v7 ( + other stuff)
scootie
any idea what the superuser password is for the PN 585 v7?
ive tried serial number
9 REPLIES 9
bobpullen
Fixes: 316
Re: super user password 585 v7
You tried 'admin' as the user and leaving the password blank?
scootie
nope no go with that.
am after the SuperUser access. ive got the Administrator rights with my own password setup and able to telnet in but the superuser password i cant work out.
all the threads on this are for be an o2 and there superuser passwords are SuperUser/O2Br0ad64nd
scootie
asbo wonders if the tech user profile gives same access as SuperUser and if ever likely PN would give the password out  Smiley
_{Administrator}=>user list
User                              Flags Role
Administrator                    U    Administrator
tech                              R    TechnicalSupport
luke                                    Administrator
scootie
Re: super user password 585 v7 ( + other stuff)
error stats certainly has a bug in it. line atten is down from 49-50db on my netgear to 47 on the 585 but no better sync
Link Information
Uptime: 0 days, 1:27:03
DSL Type: G.992.3 annex A
Bandwidth (Up/Down) [kbps/kbps]: 843 / 3,131
Output Power (Up/Down) [dBm]: 12.5 / 0.0
Line Attenuation (Up/Down) [dB]: 28.5 / 47.0
SN Margin (Up/Down) [dB]: 6.0 / 12.5
Loss of Link (Remote): 0
FEC Errors (Up/Down): 4,294,967,264 / 0
CRC Errors (Up/Down): 4,294,967,264 / 10
HEC Errors (Up/Down): 0 / 7
tobykim
I didn't even know there was a superuser access, I knew about the one for o2 but that was only so you could actually see the stats as the firmware wasn't standard and users couldn't access the information, it's available to view on the PN one
scootie
may be there isnt then. ive had play through all the CLI and ive not bein stoped at any point so it does apper to allow complete access on the admin user rights.
i still think the router is pants thoe. i switched back to my netgear at about 9pm and it gave me away better sync than what the 585 with a sync at midday did. 100kbps extra upsteam and 400kbps downstream.
done a library pieace on forceing the adsl modulation on 21cn
http://community.plus.net/library/hardware/forcing-adsl-modulation-on-thomson-585v7/
who does the reviewing of newly summited library write ups?
scootie
Has any one tried setting up QOS on the 585 v7. if so am all ears as to what you learnt
tobykim
I've gone the opposite way and swapped my netgear for the speedtouch, I found my netgear was dropping sessions although all the lights were lit there was nobody home, been fine since I've been using the speedtouch the netgear was a DG834v4, I've got a 2wire in the house somewhere so one day I'm going to dig it out and give it a try
scootie
just had ago at what i like to call the poor mans dmz on this router and assigned the wan ip to my xbox.
guess what every single device in the house lost its net including the xbox.
looking on the xbox network config it had picked up the public ip but was shocked to see the routers lan ip had changed from the normal 192.168.1.254 to somthing else yet the 1st dns was the normal 192.168.1.254 ip and the second dns was somthing totaly random.
didnt get chance to write all the ip's down as i had an angry mob wanting to know why there net was down, try again when its only me on the net.
