line fault
- line fault
- « Previous
- Next »
Re: line fault
17-10-2011 1:01 PM
Re: line fault
18-10-2011 11:03 PM
The new router arrived today - I have plugged it into the test socket, and used all the filters and cables in the new box (even though mine were all new last week).
Here are the stats:
Maximum Bandwidth (Up/Down) [kbps/kbps]: 308 / 2,912
Bandwidth (Up/Down) [kbps/kbps]: 320 / 2,784
Line Attenuation (Up/Down) [dB]: 23.0 / 39.5
SN Margin (Up/Down) [dB]: 6.0 / 15.5
I'm still not having any disconnects that I can notice, its just the sync speed is way low, could you run the line test again please? also, if no fault could you reset the SNR, I feel the 15.5 is stopping it syncing higher?
All we have ruled out, is that the router isn't the problem - I was so hoping the new one would just back on and sync properly!
Knotty
Re: line fault
18-10-2011 11:27 PM
Re: line fault
19-10-2011 1:26 PM
Any news on the new test results?
Knotty
Re: line fault
19-10-2011 11:27 PM
I'll take a look for you in the morning and wee if I can make any improvements.
Jojo
Re: line fault
20-10-2011 12:55 AM
Quote from: Joanne wee if I can
Jojo
Fnarr, fnarr...
Re: line fault
20-10-2011 8:13 AM
@Knotty,
I've reset the SNR now as the line seems to be holding up well. If the SNR stays low it'll be a good indication that the new router has helped. If not, we'll have to see where to go to from there. I'll check back on it in a bit and see how it's going.
Jojo
Re: line fault
20-10-2011 9:41 AM
That looks a lot better now, Your profile is now 4500 which I've set at our end. You should see the increase shortly.
Jojo
Re: line fault
20-10-2011 4:50 PM
BT results below:
Download speedachieved during the test was - 4014 Kbps
Additional Information:
Your DSL Connection Rate :5472 Kbps(DOWN-STREAM), 320 Kbps(UP-STREAM)
IP Profile for your line is - 4500 Kbps
Re: line fault
20-10-2011 4:52 PM
- « Previous
- Next »
