Changes to BT IP profile system in last 4-5 days?
- Changes to BT IP profile system in last 4-5 days?
14-10-2011 9:08 PM
Quote Download speedachieved during the test was - 2233 Kbps
For your connection, the acceptable range of speeds is 1200-4000 Kbps.
Additional Information:
Your DSL Connection Rate :4086 Kbps(DOWN-STREAM), 440 Kbps(UP-STREAM)
IP Profile for your line is - 3604 Kbps
My Exchange isn't showing as amber let alone red for VP capacity and this started Monday ish. M y speeds are always 2300ish kbs for a 3500k+ IP profile, my speed would normally be in region of 2600-2800. So going by the 80% rule I should be getting 2880 from that IP profile.
So wonder if BT have been Fixing/breaking the system.
Re: Changes to BT IP profile system in last 4-5 days?
14-10-2011 10:13 PM
14-10-2011 11:26 PM
15-10-2011 12:00 AM
15-10-2011 7:56 AM
Quote from: Strat As has also been discussed the Delta Report from BT that updates PN systems is not being updated until around December time.
The cause of some of the posted profile problems appears to be that BT delta reports are now effectively lower than they would have been under the old system. I would have thought that someone should be trying to get that remedied rather than just waiting for December. It appears that this is not accepted as a fault by Plusnet ( comment by Jojo in a post in answer to my query) but an informed comment elsewhere http://forums.thinkbroadband.com/unhappiness/t/4052983-re-plusnets-profile-system.html ; thinks otherwise.
15-10-2011 1:38 PM
Quote from: Ransomefan The cause of some of the posted profile problems appears to be that BT delta reports are now effectively lower than they would have been under the old system.
Unfortunately what people think and reality can differ. Have you any firm evidence that the BT delta reports supply incorrect information? I've seen instances in these forums where the history posted by the user supports what the delta report system has done, taking into account the 'increase' delays built into that horrid system.
15-10-2011 4:08 PM
Quote from: spraxyt . Have you any firm evidence that the BT delta reports supply incorrect information? I've seen instances in these forums where the history posted by the user supports what the delta report system has done, taking into account the 'increase' delays built into that horrid system.
In my case I have checked regularly on the BT speed tester and it has since the 7th Oct. reported my IP profile as 4500kbps. When I posted that my down load speed had dropped and quoted my BT IP. I was advised that the delta report showed 4000 and this has continued.
I have only extracted quotes from the recent pages one thread (88.2% profile) but I recall there are other threads addressing the same issues.
Jojo-Just bear in mind though that these may drop down again with the next delta reports, as we're still getting the ones in 500/1000 increments below what your profile is reporting.
IP Profile for your line is - 6098 Kbps PN Profile =5500
BT Speedtester is now reporting a profile of 6387 (was 6000). Plusnet still shows my speed as 6000 at the moment
BT reported my profile as 11815 k just now and it has been >11000 for many days but PN profile seems to have got stuck on 10000
I've upped your profile to 11000 but the delta report is still showing at 10000 on BTs side, so it's likely to update and override ours I'm afraid
Is PN pursuing BT as to why its delta reports seem to be providing incorrect information that is diddling us, the customer, out of available speed?
Jojo quote It still seems to be giving the old profile with regard to the sync
Jojo again ( to me) You'll see plenty of examples similar to yours in this thread.
At the current moment: Sync rate - 13759K BT Profile - 12135K Plusnet Profile - 12000K
15-10-2011 4:39 PM
Test1 comprises of Best Effort Test: -provides background information.
Download Speed
2205 Kbps
0 Kbps 7150 Kbps
Max Achievable Speed
Download speedachieved during the test was - 2205 Kbps
Your DSL Connection Rate :4064 Kbps(DOWN-STREAM), 160 Kbps(UP-STREAM)
IP Profile for your line is - 2500 Kbps
My speed has certainly taken a hit today I was getting a download of 4 Mbps and nothing has changed at my end. Could it be the new profiling?
To be is to do - Kant
do be do be do - Sinatra
15-10-2011 5:24 PM
It's unusual to see such a low upstream, I would raise a fault if I were you.
15-10-2011 7:05 PM
16-10-2011 9:25 AM
Quote My speed has certainly taken a hit today I was getting a download of 4 Mbps and nothing has changed at my end. Could it be the new profiling?
This morning my "current line speed" is 4.5Mbps after being 2.5 yesterday, is this the how the new profiling works or has this been manually initiated?
16-10-2011 5:12 PM
16-10-2011 5:16 PM
I rebooted last night and my current line speed a la PN is now 4.5 Mbps
better but we will see what it is on Monday, I have a open ticket
16-10-2011 5:30 PM
16-10-2011 7:27 PM
Thanks for your input
Its been going on a while though, and I have a live ticket
The support team have told me I haven't got a problem but I keep having these sort of events. I all goes to log the story for a final resolution
