line fault
- line fault
Re: line fault
04-10-2011 7:30 PM
Re: line fault
04-10-2011 7:51 PM
Re: line fault
04-10-2011 11:09 PM
Re: line fault
05-10-2011 12:29 PM
I am now more concerned as link:csa removed - CSC Analyst has just sent me an e-mail saying my equipment could be at fault, when clearly I have gone through all the normal tests, including a new router!
My fault has looped right back round to the start of the fault - I feel no closer to getting a resolution.
adie:orange CSA name removed as per link:rules ]
Re: line fault
05-10-2011 12:39 PM
Quote Test Result: Fail - Fault located at customer apparatus (appointment required)
Description: FAULT - Loop (Rectified)
At this juncture I'd recommend that we take a detailed look at your set up, we want to avoid booking an engineer visit that could lead to charges for yourself. Can you describe to us in as much detail as possible how your equipment is set up (in terms of from the master socket out to filters, phones and the router...
Re: line fault
05-10-2011 1:09 PM
I will take a look at the house wiring and report back later today. I have a feeling the second wall outlet is run from the line outside - meaning it is split outside (note this is how I assume BT did it when first installed - not my wiring)
If that is the case, I will just rip it all out as that could be the problem.
Apart from that, I have two filters on two sockets, both new, one has the phone( which is currently unplugged), and the other has the new router.
I am atleast thankful that a test has come back with a fault that I can look in to.
Re: line fault
05-10-2011 1:44 PM
Re: line fault
05-10-2011 2:00 PM
From my experience (two line faults this year), it seems quite common for BT's automated tests to report 'fault at customer premises' when the fault is on the line itself. Last time it was in the underground section of the line.
Whilst I can understand why Plusnet want to do everything possible to protect you from the risk of being charged for the callout, I do think it is unreasonable that the test reports don't at least acknowledge the uncertainty in the test findings.
Good luck.
Trevor
Re: line fault
05-10-2011 2:41 PM
Quote Whilst I can understand why Plusnet want to do everything possible to protect you from the risk of being charged for the callout
Absolutely and purely from experience I do have faith in the testing system being used here, please bear in mind that these are phone fault specific tests as opposed to broadband ones which can be less specific in their output.
Re: line fault
05-10-2011 3:00 PM
Re: line fault
05-10-2011 5:00 PM
In the mean time I have got hold of two new sockets, I am going to re-wire the lot just to protect myself. Once this is done, if the problem persists I will expect a BT engineer very promptly due to the downtime I have already experienced.
Re: line fault
05-10-2011 5:05 PM
Re: line fault
05-10-2011 5:05 PM
Could we perhaps agree to a call some time tomorrow morning?
Adam.
Re: line fault
05-10-2011 5:57 PM
I just put the router back in the test socket so that all extensions are disconnected. Started up router stats and rung the house phone - Left it a few minutes, attached a different filter and did the same test again.
Attached it the image of the drop in NR. Does this enlighten anything?
edit: added the graph of connection speed at the same time. note that I am capped at 135kb still.
Re: line fault
05-10-2011 6:51 PM
Thanks,
Knotty
