help me get plusnet as home page
- help me get plusnet as home page
19-09-2008 4:27 PM
hi just fairly new but i would like to get plusnet as homepage [so its on the screen as soon as i switch on] i have a photo on now of my 2 g/sons grinning ear to ear and i keep wondering what they are upto next lol :also i need a new modem [bt viyager 2110 who supplies that x carolP
Message 1 of 3
(1,116 Views)
2 REPLIES 2
Re: help me get plusnet as home page
19-09-2008 4:29 PM
Hiya,
Why do you need a new modem?
If you are using Internet Explorer, click on your tools menu and then select "Internet Options" (You can also access this from the control panels.
Just change the address in that page and click on apply and then ok.
That should then set your home page.
Message 2 of 3
(346 Views)
19-09-2008 4:39 PM
Have been pipped at the post.... literally !...
Do you mean you want to change your "wallpaper" (the pic of your two little fiends) ?
or Have Plusnet come up when you connect to internet instead of Google?
for second version....
Get Plusnet Home page on your screen.
Right click on the address and then "copy"
now go to bottom left corner, click on "START" > Control Panel > Internet Options
You will have a grey box with General tab
In the white window (entitled To create home page......)
"paste" the url for Plusnet home page,
Then "select" it
bottom of grey panel.... click on apply
then O.K.
Plusnet will be your "default" home page when you connect to the internet.
Then "select" it
then O.K.
Message 3 of 3
(346 Views)
