connection oddities
- connection oddities
connection oddities
19-02-2009 9:47 AM
We have been having some odd behaviour with our internet connection for the last 6 months, when the line drops the router will not reconnect unless we first dial 1471, or dial 150 and get a line test performed. Can anyone provide some advice as to what is going on?
apologies if this is the wrong forum
Message 1 of 8
(1,426 Views)
7 REPLIES 7
Re: connection oddities
19-02-2009 9:57 AM
My first thought is that you have a high resistance joint somewhere and dialling out clears it temporarily but I have never heard of this happening before.
Have you tried the quiet line test - dial 17070 option 2
Message 2 of 8
(664 Views)
19-02-2009 10:07 AM
In the past I have had similar experiences. I use to do the quiet line test and could hear noise on the line which decreased when listening then the router establish a connection and it was fine for a few days.
Does the phone get used a lot? I believe that the problem is down to a poor sealing of a joint and moisture ingress. Using the phone 'dry' out the joint.
Message 3 of 8
(664 Views)
19-02-2009 10:30 AM
Thanks i will try the quiet line test tonight.
the phone does not get used that often, infact we went for quite a while last year not being able to recieve incomming calls. the first we knew about that was when i tried to phone home but couldnt. a line test cleared that too.
Message 4 of 8
(664 Views)
19-02-2009 11:20 AM
Quote from: itsme Does the phone get used a lot? I believe that the problem is down to a poor sealing of a joint and moisture ingress. Using the phone 'dry' out the joint.
An increased "drying effect" can result by applying ringing current on the line. Use a mobile if handy, or 17070 option 1 for an automatic ring-back.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
Message 5 of 8
(664 Views)
21-02-2009 2:10 PM
Hi, sorry about the delay, i did the quiet line test and that was ok, no pops or crackling on the line.
dan
dan
Message 6 of 8
(664 Views)
17-03-2009 2:19 PM
Thanks for all the help, i have managed to track down the fault and get it fixed. Would you believe it was the master socket. I had one of the old pre test socket (NT5e? ) type. This has been replaced with a NT5e type bt socket and the extension moved to a ADSLnation XTE-2005 Master Faceplate.
Result = synching at a far more respectable 1500 with an average download speed of 1376, no more dropped connections and no more crackly phone line :)..
Message 7 of 8
(664 Views)
17-03-2009 2:26 PM
We were wondering.
Thanks for posting the resolution.
Message 8 of 8
(664 Views)
