Help! Failing to sync
- Help! Failing to sync
16-03-2009 4:12 PM
Unfortunately the router is no longer syncing and and there is a large buzz on the telephone line.
I am using a Netgear 834G v3 router with the latest firmware installed which is meant to be compliant.
[Moderator's note by Adie (Adiewoo) changed all caps title as per Forum Rules]
[color=green][PUG Moderator's note by David (spraxyt) title extended to better describe the problem]
Re: Help!
16-03-2009 4:31 PM
Re: Help!
16-03-2009 4:44 PM
Re: Help!
16-03-2009 4:47 PM
Re: Help!
16-03-2009 5:26 PM
wheres adeiwoo's reply has his solid 24 carat gold phone line broke
Re: Help!
16-03-2009 5:34 PM
Re: Help!
16-03-2009 6:12 PM
I accepted the offer of participating in the trial months ago as I was at home. However months have passed since the order was placed and I am now working in the states and trying to relay all this information to my father who has limited technical knowlege.
He says he ran the line test and after holding for around 2 minutes listning to a message saying "Performing line noise test" he hung up. He says he didn't get any result. Should he have stayed on the line longer to get the result? Presumably there is not a noise problem on the line because when he unplugs the router, the buzz dissapears from the line. The noise is definately coming from the router trying to sync. That's why I was wondering if it might be a splitter problem.
He is going to run the line test again and hold on longer this time. Is there any other advice I should give. What is the next step to try and resolve this if the line test is good?
Re: Help!
16-03-2009 6:28 PM
That's all you are looking for from the quiet line test. If the buzzing disappears when the router is unplugged that indicates there is no obvious problem with the line.
Are there extension phone sockets? If so have you got filters in every extension that has anything plugged in? (including things like Sky boxes).
If he unplugs everything except the filter and router does the router sync then?
Re: Help!
16-03-2009 7:16 PM
There is a telephone attahced via the ADSL filters to both the master socket and the extension. The router is attached via the ADSL filter and the extension. He has tested the router by plugging straight into the master socket also.
Line test is completely silent when using the BT test socket and also the regular socket when the "Router is unplugged". The buzz on the line is only apparent when the router is attached and trying to negotiate a connection. Router status says something along the lines of "Trying to negotiate an LCP connection".
Have tested router with both phones disconnected from the line but still unable to establish a connection?
I think I have covered all bases except for trying new filters.
What's next? I'm wondering if we should revert back to DSL max as we are not in a prime position now to be testing this. I opted to participate months ago when I was at home because I have a good technical knowlege but as I am not at home now, I feel helpess to do anything. I was not aware that it was going to take several months to set up.
Re: Help!
17-03-2009 12:01 AM
I don't know whether noise from the router should be audible during syncing, though I'd have guessed not.
I think trying a different filter is the first step, any chance of trying a different router too?
Having eliminated those some mistake in moving your connection to 21CN then seems the only thing left.
Re: Help!
17-03-2009 1:13 AM
Trying another router is not really an option because my dad won't know what to do with it.
If any PN staff are monitoring this, please check ticket #27773955
Re: Help! Failing to sync
17-03-2009 3:58 PM
I've not had any feedback from PN at all.
