can my pn ip profile be nudged up please?
- Re: can my pn ip profile be nudged up please?
10-05-2010 12:47 PM
thanks
chris.
chris.
Message 1 of 6
(838 Views)
5 REPLIES 5
10-05-2010 3:50 PM
It's matching at 2000 on both our and BTs side at the moment so no change to be done I'm afraid.
Message 2 of 6
(445 Views)
10-05-2010 4:03 PM
Hmm, odd...
DownStream Connection Speed 2848 kbps
UpStream Connection Speed 416 kbps
According to Kitz.co.uk I should be configured for 2500k at this speed.
Must have gone back down as it was at 2500k on the BT test earlier today. I'll wait for it to rise again?
Matt - Can you confirm that my upstream is now uncapped as my upstream connection speed is relatively low (I am connecting via ADSL1 now G.DMT as opposed to my exchange default of ADSL2 as I get a higher sync speed on ADSL1).
Thanks, Chris.
Thanks, Chris.
Message 3 of 6
(445 Views)
10-05-2010 4:48 PM
I posted on your other thread Chris - the order's due to complete on the 13th because the system I used set an incorrect lead time. Sorry about that.
Message 4 of 6
(445 Views)
10-05-2010 5:57 PM
Ok Matt - Thanks.
Can you confirm this will work with G.DMT ADSL1 as I don't want to go back to ADSL2 as I am getting better sync speeds with ADSL1.
Message 5 of 6
(445 Views)
12-05-2010 9:41 AM
AIUI the service works with both, so you should be fine.
Message 6 of 6
(445 Views)
