adsl2+ - speeds alot lower than ip profile
Stigfish
Hi folks,
Can any one shed any light on this for me please, I've been regraded to adsl2+, I'm only getting around 6.5Mbps at the moment even though I'm currently syncing at 16,527 Kbps, the BT Speedtest has my IP Profile as 14.58 Mbps. Is the slow speed just a process of the 10 day thing (ie am i being impatient) or am i missing something?  Grin
____________________________________________________________________________
Download speedachieved during the test was - 6.55 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 14.58 Mbps
Upload speed achieved during the test was - 1.14Mbps
Additional Information:
Upstream Rate IP profile on your line is - 832 Kbps
Downstream 16,527 Kbps
Upstream 1,239 Kbps
VPI/VCI 0/38
Type PPPoA
Modulation ITU-T G.992.5
Latency type Interleaved
Noise margin (Down/Up) 6.1 dB / 6.1 dB
Line attenuation (Down/Up) 22.5 dB / 13.0 dB
Output power (Down/Up) 0.0 dBm / 12.8 dBm
31 REPLIES 31
Oldjim
Resting Legend
Fixes: 63
Re: adsl2+ - speeds alot lower than ip profile
Stigfish
Cheers Oldjim, I'm getting:
Estimated line speed:
    Not recorded (service activated before we introduced estimates).
Current line speed:
    7.15 Mb
Oldjim
Resting Legend
Fixes: 63
give them a call asking that the Plusnet profile be increased to match the BT IP profile - or raise a ticket
Stigfish
Thanks again Oldjim, I've raised a ticket (52004730).
adamwalker
Fixes: 221
@Stigfish
I've just had a gander at your account and can see Jojo picked this up for you from Twitter, I thought I recognised your avatar! Smiley
 Adam Walker
Stigfish
Cheers Adam... things aint looking too great, hoping its just the 10day line sync thing... connection speed has dropped from 16000kbps to 12993kbps
ADSL Link Downstream Upstream
Connection Speed 12993 kbps 1244 kbps
Line Attenuation 24.5 db 12.7 db
Noise Margin 12.2 db 5.8 db
jojopillo
Hi Stigfish,
Your SNR is currently 11dB so this will make the sync rate a little lower. Are you using any extension cables/sockets? Do you have a test socket you can plug into?
Jojo Smiley
Stigfish
Yes its on an extension Jo, but i've tried it in the test socket with no difference, very strange, when i was on normal adsl i sync'd at 8192kbps and had a perfect line, that was only a matter of days ago, im not up on this adsl stuff so dont know the ins & outs, but until now my connection has always been pretty spot on (no disconnections etc).
Thanks  Smiley
jelv
Fixes: 10
When you tried it in the test socket was it that the result of a speed test was just the same or that the sync speed, noise margin were unchanged?
If using an extension is causing extra errors or disconnects it could take many days if not weeks for the improvement given by using the test socket to show through in speed test results.
When on ADSL1 you were syncing at full speed so there would have been plenty of spare margin and the extension lead would not have been a factor. Now it's attempting to run at higher speeds which will give a lower margin the extension could be significant.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Stigfish
Hi Jelv,
I didnt run a speedtest from the test socket, I just noted that the sync speed and noise margin were unchanged.
Cheers
Craig.
jelv
Fixes: 10
The problem is that the target noise margin may have been pushed up as a result of using the extension so when you used the test socket you'd get a similar connection.
If you leave it in the test socket for a few days and it stays stable with no disconnections you could then ask PN (via these forums) to reset the line which would set the target back to normal and give you higher speed. If that stayed stable (still using the test socket) for a week or so you could then try the extension again to see if it caused the speed to drop.
Stigfish
Jelv,
Thanks mate I see where you are coming from, I'd do that now, I'll run it from the test socket for a few days, thanks again for your advice, much appreciated.
Craig.
Stigfish
Ok I'm now running from the test socket and will continue to do so for 3 or 4 days as suggested, below is a paste of my router adsl status page (whilst in test socket), included it just in case anyone sees anything obvious in the meanwhile  Smiley
thanks for the help so far folks, I very much appreciate it.
Craig.
adslctl: ADSL driver and PHY status
Status: ShowtimeRetrain Reason: 8000
Channel: FAST, Upstream rate = 1240 Kbps, Downstream rate = 12978 Kbps
Link Power State: L0
Mode:                  ADSL2+
Channel:                Fast
Trellis:                U:ON /D:ON
Line Status:            No Defect
Training Status:        Showtime
                Down            Up
SNR (dB):      12.2            5.8
Attn(dB):      24.5            12.7
Pwr(dBm):      0.0            12.8
Max(Kbps):      15492          1224
Rate (Kbps):    12978          1240
                        G.dmt framing
K:              203(0)          54
R:              14              0
S:              1              1
😧              64              1
                        ADSL2 framing
MSGc:          59              46
B:              202            53
M:              1              1
T:              2              1
R:              14              0
S:              0.4992          1.3670
L:              3477            316
😧              64              1
                        Counters
SF:            39929          38059
SFErr:          0              0
RS:            5190900        0
RSCorr:        362            0
RSUnCorr:      0              0
HEC:            0              0
OCD:            0              0
LCD:            0              0
Total Cells:    19832660                526605
Data Cells:    510522          46705
Drop Cells:    0
Bit Errors:    0              0
ES:            0              0
SES:            0              0
UAS:            39              0
AS:            648
INP:            1.03            0.00
PER:            16.22          17.77
delay:          7.98            0.34
OR:            32.04          23.40
Bitswap:        25              0
Total time = 6 min 46 sec
SF  = 39929
CRC = 0
LOS = 0
LOF = 0
ES  = 0
Latest 1 day time = 6 min 46 sec
SF  = 39929
CRC = 0
LOS = 0
LOF = 0
ES  = 0
Latest 15 minutes time = 6 min 46 sec
SF  = 39929
CRC = 0
LOS = 0
LOF = 0
ES  = 0
Previous 15 minutes time = 0 sec
SF  = 0
CRC = 0
LOS = 0
LOF = 0
ES  = 0
Previous 1 day time = 0 sec
SF  = 0
CRC = 0
LOS = 0
LOF = 0
ES  = 0
Showtime Drop Reason:  8000
Last Retrain Reason:    8000
jojopillo
Hi Craig,
The target SNR is 12dB at the moment, so if it hasn't improved in the test socket, once your 10 days are up I can request it reset back to 6dB.
Jojo Smiley
