Would somebody please check BT speedtester?
- Re: Would somebody please check BT speedtester?
04-10-2008 10:49 AM
Java Plug-in 1.6.0_10-rc
Using JRE version 1.6.0_10-rc Java HotSpot(TM) Client VM
User home directory ----------------------------------------------------
c: clear console window
f: finalize objects on finalization queue
g: garbage collect
h: display this help message
l: dump classloader list
m: print memory usage
o: trigger logging
q: hide console
r: reload policy configuration
s: dump system and deployment properties
t: dump thread list
v: dump thread stack
x: clear classloader cache
0-5: set trace level to <n>
java.lang.NumberFormatException: null
at java.lang.Integer.parseInt(Unknown Source)
at ProgressBarPT.getIntValue(ProgressBarPT.java:181)
at ProgressBarPT.init(ProgressBarPT.java:199)
at sun.plugin2.applet.Plugin2Manager$AppletExecutionRunnable.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Exception: java.lang.NumberFormatException: null
In start method 1
Java is up to date.
04-10-2008 11:01 AM
04-10-2008 11:17 AM
04-10-2008 11:28 AM
This is a standard (permanent) error.
All the BT speedtester is good for is for showing your BT profile.
It doesn't check speed because it crashes at a figure of 96%.
Use the Plusnet speedtester - especially out of hours and use it on support tickets.
04-10-2008 11:55 AM
I came on here intending to ask about it and was pleased to find that others were having the same problem because I thought there was something wrong with my Java Runtime setup. Using IE7 I got no error message at all. The Java symbol flashed up momentarily and then changed to a little cross in the corner. I then tried using FF and got a little message: "Applet: ticker-applet2 not inited" . I assumed this meant that a Java applet hadn't been initialised correctly which led me to suspect that my Java Runtime had become corrupted.
Thanks for subduing my fears.
04-10-2008 1:11 PM
FF 3.0.3 and Java 1.6 update 7
The UK's next generation net infrastructure is safe in BT's hands.....pure nonsense.
Why don't the government pay someone who knows how to run this stuff like Cogent or Level 3 to build, operate and maintain it rather than a dinosaur that should have been allowed to become extinct years ago and has been forced into the 21st Century by regulator pressure.
04-10-2008 1:33 PM
04-10-2008 3:09 PM
Quote from: axisofevil Why does it use Java?
Probably because it is cross platform so they don't have to write code for multiple browsers
04-10-2008 3:26 PM
I get "Exception access denied, java.net socket denied permission " errors
so to me - it is not "fit for purpose" and a waste of time
04-10-2008 3:28 PM
04-10-2008 4:58 PM
There needs to be a test component to monitor from the client side and provide feedback to the server application.
The tend to use either Java (BT) or Adobe Flash (Plusnet's own speedtester)
