Website check
- Re: Website check
Website check
07-07-2014 11:28 AM
Re: Website check
07-07-2014 11:30 AM
Just tried http://downforeveryoneorjustme.com/ and got error 502 Bad Gateway so that site is screwed as well
Re: Website check
07-07-2014 11:31 AM
Re: Website check
07-07-2014 11:33 AM
Re: Website check
07-07-2014 11:35 AM
Re: Website check
07-07-2014 12:42 PM
So doubt it's a PN issue.
Re: Website check
07-07-2014 12:44 PM
Re: Website check
07-07-2014 1:33 PM
Re: Website check
07-07-2014 1:58 PM
Quote from: 11110_110 lol... yeah i just tried this one as well... http://downforme.org/ seems to work on that.
Same here, although it claims it is only down for me
Therefore I would not rely on it too much
I would ask the host if they are having any known issue(s)
Re: Website check
07-07-2014 4:48 PM
Re: Website check
07-07-2014 4:54 PM
Tracing route to pgl.yoyo.org [95.172.9.82]
over a maximum of 30 hops:
1 57 ms 99 ms 99 ms 192.168.1.254
2 79 ms 34 ms 83 ms lo0-central10.ptw-ag03.plus.net [195.166.128.197]
3 34 ms 34 ms 34 ms link-a-central10.ptw-gw01.plus.net [212.159.2.152]
4 34 ms 34 ms 33 ms xe-4-3-0.ptw-cr01.plus.net [212.159.0.244]
5 35 ms 34 ms 34 ms ten0-1-1-2-t40-mse1.router.uk.clara.net [195.66.224.66]
6 35 ms 34 ms 34 ms tengige0-0-0-0-gs2-mse1.router.uk.clara.net [195.157.3.22]
7 35 ms 34 ms 34 ms tengige0-1-1-0-gs2-mse2.router.uk.clara.net [195.157.3.26]
8 34 ms 34 ms 34 ms g7-1-gs2-ar2.router.uk.clara.net [195.157.6.58]
9 34 ms 34 ms 33 ms po1.br1.str.uk.idllt.net [80.168.71.254]
10 34 ms 34 ms 34 ms po3.br2.str.uk.idllt.net [78.40.33.10]
11 35 ms 34 ms 33 ms gi1-48.ir2.str.uk.idllt.net [78.40.33.18]
12 * * * Request timed out.
13 * * * Request timed out.
14 *
Re: Website check
07-07-2014 4:58 PM
C:\Windows\system32>tracert pgl.yoyo.org
1 68 ms 70 ms 96 ms dsldevice.lan [192.168.1.254]
2 77 ms 33 ms 38 ms lo0-plusnet.ptn-ag04.plus.net [195.166.130.17]
3 50 ms 31 ms 46 ms link1-plusnet.ptn-gw01.plus.net [84.92.7.92]
4 32 ms 39 ms 39 ms xe-1-2-0-141.ptw-cr01.plus.net [212.159.1.168]
5 38 ms 31 ms 46 ms ten0-1-1-2-t40-mse1.router.uk.clara.net [195.66.
224.66]
6 32 ms 32 ms 31 ms tengige0-0-0-0-gs2-mse1.router.uk.clara.net [195
.157.3.22]
7 32 ms 31 ms 32 ms g8-1-gs2-ar2.router.uk.clara.net [195.157.6.54]
8 54 ms 51 ms 52 ms po1.br1.str.uk.idllt.net [80.168.71.254]
9 32 ms 33 ms 32 ms 78.40.33.14
10 35 ms 88 ms 38 ms 78.40.33.6
11 * * * Request timed out.
14 * * * Request timed out.
15 * * * Request timed out.
16 * * * Request timed out.
17 * * * Request timed out.
18 * * * Request timed out.
30 * * * Request timed out.
Trace complete.
C:\Windows\system32>[/code]
Re: Website check
07-07-2014 5:11 PM
[tt]Host Loss% Snt Last Avg Best Wrst StDev
1. 192.168.0.254 0.0% 5 52.0 62.4 52.0 72.8 8.2
2. lo0-central10.ptw-ag03.plus.net 0.0% 5 16.4 17.6 16.4 20.3 1.4
3. link-a-central10.ptw-gw01.plus.n 0.0% 5 16.1 16.7 16.1 17.1 0.0
4. xe-4-3-0.ptw-cr01.plus.net 0.0% 5 16.2 16.2 15.9 16.5 0.0
5. ten0-1-1-2-t40-mse1.router.uk.cl 0.0% 5 16.9 16.9 16.5 17.1 0.0
6. tengige0-0-0-0-gs2-mse1.router.u 0.0% 5 16.8 17.0 16.8 17.2 0.0
7. tengige0-1-1-0-gs2-mse2.router.u 0.0% 4 16.9 17.0 16.8 17.0 0.0
8. g7-1-gs2-ar2.router.uk.clara.net 0.0% 4 16.8 53.8 16.7 164.6 73.9
9. po1.br1.str.uk.idllt.net 0.0% 4 17.0 26.9 17.0 56.7 19.8
10. po3.br2.str.uk.idllt.net 0.0% 4 17.4 17.1 16.5 17.4 0.0
11. gi1-48.ir2.str.uk.idllt.net 0.0% 4 17.3 22.4 17.3 34.4 8.0
12. ?
[/tt]
Re: Website check
07-07-2014 5:19 PM
Re: Website check
07-07-2014 5:28 PM
Does the website in question, fully load on your side ?
