Slow download speeds and limited connectivity all the time
- Slow download speeds and limited connectivity all ...
02-02-2012 8:04 PM
I keep getting "Limited Connectivity" all the time whilst either streaming or downloading everything will be going fine then all of a sudden i disconnect for 2-5 minutes at a time. This happens on both wireless and when i connect to my router via Ethernet cable
Im currently trying to download a new game which is 25GB big which as you can imagine is taking some time the download has currently been on for 6 hours and because of slow speeds and this limited connectivity problem i have only managed to download 2 GB, if anyone has a solution for this it would be much appreciated
Message 1 of 7
(7,315 Views)
6 REPLIES 6
Re: Slow download speeds and limited connectivity all the time
02-02-2012 8:23 PM
According to service status the slow speeds problem that has been present through the day should now be fixed.
Assuming your router sync speeds are normal you could try disconnecting from Plusnet using the router's web interface, then connect again. That will ensure your traffic management profile is correct and probably assign you to a different gateway which might be less congested. Gateway checker http://usertools.plus.net/@gateway/.
David
Message 2 of 7
(521 Views)
02-02-2012 8:28 PM
Service is so bad tonight that the link for the gateway is timing out
![Shocked Shocked](/html/@0AB4C7C43827ACF5B296F730FEC5B1DE/images/emoticons/shocked.gif)
Message 3 of 7
(521 Views)
02-02-2012 8:39 PM
I have had this problem for about a month now, not just tonight
Message 4 of 7
(521 Views)
02-02-2012 9:18 PM
"Limited connectivity" means "tried to connect but failed". If that's what your computer is telling you and it happens with both a wired and a wireless connection and you're quite sure about that then your router must be faulty.
Message 5 of 7
(521 Views)
02-02-2012 9:49 PM
The fault was at my end, something must of happened to my dongle so i went out and bought a new one dont know why i didnt do this sooner anyway, im now downloading a 1.83MBs and am not getting disconnected.
Thanks to everyone for trying to help
Message 6 of 7
(521 Views)
07-02-2012 9:26 AM
Message 7 of 7
(521 Views)
