TGb 582n - Which firmware version
- Re: TGb 582n - Which firmware version
22-02-2013 9:05 PM
My TG 582n is running version 8.4.4.I of the firmware. What benefit would I get from upgrading it to one of the several later versions, such as 8.4.4.J or 10.2.2.B?
The router has a USB port which I don't use.
Message 1 of 2
(1,342 Views)
1 REPLY 1
25-02-2013 10:59 AM
If your Technicolor is working for you then there's no need to upgrade to the firmware you've mentioned, the upgrade is to help any potential wireless issues.
Message 2 of 2
(299 Views)
