Speed problem on ptw-ag01
- Speed problem on ptw-ag01
05-02-2014 1:40 PM
I noticed that I was getting serious buffering on video streams so ran a few speed tests and this is the result from the BT speedtest
I then changed gateways from ptw-ag01 tp pcl-ag02 and speeds are more or less back to normal
Message 1 of 3
(1,126 Views)
2 REPLIES 2
Re: Speed problem on ptw-ag01
05-02-2014 1:47 PM
Thanks, we picked this up a bit ago, we fixed it yesterday but looks like it's re-occurred. The Ops guys are currently gathering data to find the cause to fix it, but yeah if anyone else sees the problem a quick disconnect/reconnect should fix it.
Dave Tomlinson
Plusnet Technology
Plusnet Technology
Message 2 of 3
(424 Views)
05-02-2014 2:14 PM
Glad i'm on ptn-ag03
Message 3 of 3
(424 Views)
