Internet speed really slow.
- Internet speed really slow.
05-02-2014 1:05 PM
Our speed has dropped down from 4.5mb 1.01mb, the upload speed is the same speed. Our Internet Usage just got renewed today.
Someone please Explain this? Thank you.
Router DSL Settings
Link Information
Uptime: 6 days, 4:12:38
DSL Type: ITU-T G.992.1
Bandwidth (Up/Down) [kbps/kbps]: 704 / 5.600
Data Transferred (Sent/Received) [MB/GB]: 512,92 / 3,42
Output Power (Up/Down) [dBm]: 12,6 / 19,4
Line Attenuation (Up/Down) [dB]: 31,5 / 51,0
SN Margin (Up/Down) [dB]: 10,0 / 5,3
Loss of Framing (Local/Remote): 0 / -
Loss of Signal (Local/Remote): 0 / -
Loss of Power (Local/Remote): 0 / -
Loss of Link (Remote): -
Error Seconds (Local/Remote): 2.104 / -
FEC Errors (Up/Down): 1.489 / 926.347
CRC Errors (Up/Down): 405 / 6.298
HEC Errors (Up/Down): - / 113.062
Router DSL Settings
Link Information
Message 1 of 7
(850 Views)
6 REPLIES 6
Re: Internet speed really slow.
05-02-2014 1:23 PM
Hi aldabbagh,
I've just checked over your line, I can see that your line is connecting at around 5.3Mb. I've had a look at the SVLAN Report which reports any known congestion issues at your exchange - this is showing as Amber which is the likely cause for the throughput issues you're seeing.
We would expect that our suppliers will add further capacity as soon as they can but I'm unable to put any fixed time frame on that I'm afraid. I can see that you're looking at moving to FTTC (Fibre) - this wouldn't effect you as you would be connected to a different SVLAN. We'll work with our suppliers to ensure further capacity is added as quickly as possible.
Message 2 of 7
(648 Views)
05-02-2014 1:25 PM
Thanks for the reply.
So it's a problem from the exchange?
Message 3 of 7
(648 Views)
05-02-2014 1:26 PM
That's right, a capacity issue at the exchange.
Our suppliers are already aware of the issue and are working on getting this resolved for you
Message 4 of 7
(648 Views)
05-02-2014 1:30 PM
Thank you very much. How long will it take to get it fixed?
Message 5 of 7
(648 Views)
05-02-2014 1:35 PM
Quote from: Chris We would expect that our suppliers will add further capacity as soon as they can but I'm unable to put any fixed time frame on that I'm afraid.
As I say, I can't really give a time frame on it I'm afraid. Usually, such issues are cleared up within a week or so.
Message 6 of 7
(648 Views)
05-02-2014 1:48 PM
Oh Okay.
Message 7 of 7
(648 Views)
